![]() | Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm? |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Taking the hub off is an overkill tbh. If you take the caliper and discs out of the way you got plenty access.. just my opinion Current:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Would this do the cassette ball joint do we think?
It would if you have the hub on a bench. In situ, the axle will be on the way so it wont work.. reason most of us do it in situ (well atleast I did) was to avoid taking the axle off and camber settings which on few alignment places can get it right. Current:
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
Taking the hub wasnt very difficult and the ball joint came out with a couple of bangs of the hammer, it gave much better access as well to everything and as a priffessional mechanic my guy wasnt going to spend hours heating and bashing things.
Yes.. its personal preference really.. to me extra bashes and being careful with the torch meant there was no change in camber or alignment when it went for a 4 wheel alignment. Current:
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
I did mine (off-side only) yesterday afternoon - a couple of hours on the drive at home for both a replacement arm (easy) and the ball-joint (totally unnecessary, but I’d bought a new one, so decided to fit it). I bought Delphi parts as they are meant to be OE in various guises and the delivered cost for both the control arm and ball joint was £77 inc. VAT. I have a full set of bushing presses, but looking at the size of the rear arm, I elected to just buy a new one, rather than press out the old bush.
Ive kept mine as a trophy too as it is not a 2 min job. I did get better at it when I changed the driver side. Only school boy error I made was that I didnt raise the suspension to the previous height before torquing and now Im 10mm lower on the driver side. Current:
They do come out with persistence:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
yep its a SMASH IT job, no real subtle way of doing it. |
Any recommends on which ball joint splitter I should get?
Definitely NOT one of the fork types as they destroy the rubber seal and necessitate a new ball joint.
Anything like this:
I didn't see another one linked, so thanks a lot for dropping that link.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
The jaw on that one may not be wide enough, I have one and had to cut it with my angle grinder to get it around the pin.
