Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm? |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Taking the hub off is an overkill tbh. If you take the caliper and discs out of the way you got plenty access.. just my opinion Current:
9th Mar 2019 12:35am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Would this do the cassette ball joint do we think?
23rd Mar 2019 5:49pm |
It would if you have the hub on a bench. In situ, the axle will be on the way so it wont work.. reason most of us do it in situ (well atleast I did) was to avoid taking the axle off and camber settings which on few alignment places can get it right. Current:
23rd Mar 2019 6:11pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 837 |
Taking the hub wasnt very difficult and the ball joint came out with a couple of bangs of the hammer, it gave much better access as well to everything and as a priffessional mechanic my guy wasnt going to spend hours heating and bashing things.
23rd Mar 2019 9:12pm |
Yes.. its personal preference really.. to me extra bashes and being careful with the torch meant there was no change in camber or alignment when it went for a 4 wheel alignment. Current:
23rd Mar 2019 9:21pm |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 61 |
I did mine (off-side only) yesterday afternoon - a couple of hours on the drive at home for both a replacement arm (easy) and the ball-joint (totally unnecessary, but I’d bought a new one, so decided to fit it). I bought Delphi parts as they are meant to be OE in various guises and the delivered cost for both the control arm and ball joint was £77 inc. VAT. I have a full set of bushing presses, but looking at the size of the rear arm, I elected to just buy a new one, rather than press out the old bush.
24th Mar 2019 12:23am |
Ive kept mine as a trophy too as it is not a 2 min job. I did get better at it when I changed the driver side. Only school boy error I made was that I didnt raise the suspension to the previous height before torquing and now Im 10mm lower on the driver side. Current:
24th Mar 2019 12:48am |
They do come out with persistence:
24th Mar 2019 5:56pm |
yep its a SMASH IT job, no real subtle way of doing it. There is nothing that can't be fixed with a hammer😜😜
24th Mar 2019 8:13pm |
Any recommends on which ball joint splitter I should get?
28th Mar 2019 8:19am |
Definitely NOT one of the fork types as they destroy the rubber seal and necessitate a new ball joint.
28th Mar 2019 8:40am |
Anything like this:
28th Mar 2019 8:50am |
I didn't see another one linked, so thanks a lot for dropping that link.
28th Mar 2019 10:14am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
The jaw on that one may not be wide enough, I have one and had to cut it with my angle grinder to get it around the pin.
28th Mar 2019 11:30am |
