![]() | Home > Maintenance & Mods (L322) > In out steering wheel motor |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
sorry don't have any photos but if you take the cowling off under the steering wheel I suspect you'll find two bits of white plastic fall on the floor. That means the spindle clip has snapped and therefore the drive spindle has become detached. If you hunt around at the back of the steering column / top of carpet etc you should also find a square threaded bolt - thats the spindle.You'll need a new clip - unfortunately its about £40 (i'll have to look for part number but I'll post later) and that clips the spindle back into the motor and steering column and thats your most likely problem.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
This might help?
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 ![]() ![]() ![]() |
Thanks for that will have a look at the weekend. |
Stripped it out today it’s the threaded plastic block has stripped no thread.
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
I thought someone (from Germany?) used to sell that part on EBay, maybe a metal version? |
Yes apparently it’s meerbush on here thanks. |
