Home > Technical (L322) > Flip key conversion?
Page 2 of 6 <123456>
dan_uk_1984
scarey wrote:
thats a good find dan...wouldn't be great if we only had one button on the remote, press once for unlock, press again for lock...looking at those pics i think i might 'cut' the tail gate unlock circuit as i dont use that anyway...
I never used to rate the tailgate button - however on this rr I have "lock on drive off" which means I'm always going to the boot to find it locked.
I s'pose I could just unlock the whole car, but the locks will probably wear out!
Post #51005 20th Feb 2011 1:47pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Just been doing some searching. Im thinking take apart orig key ( just unscerwd mine and all comes out easily). Take out inside bits and put in new key. So need to find a key with same button positioning. Found this;
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
the buttons are in same place so would all work although looks a biy cheap!
I like this one. Clearly prise of cheap badge but would have 3 button function and symbols could work and looks better IMO
or just ditch boot function as nevr see the point anyway and go for 2 button. Should be easy enough just by cutting connection between inside fob.
Or if your going down bm route i personally think this one better looking;
although i don't get how transferable as rr key 1 and 2 buttons side by side where as bm key old and converted 3 in line.
Can't decide which one but going to order a shell and see what happens. Battery won't be issue as will use orig.
Post #51081 20th Feb 2011 10:43pm
Bear in mind that presenting a Vauxhall, BMW or any other key other than ORIGINAL at point of sale will almost certainly end any deal that has been done.....
People want original car, original equipment and original paperwork when buying expensive second-hand cars....
Post #51084 20th Feb 2011 10:49pm
dan_uk_1984
Nick,
The last BMW key you linked to there is not a flip key. That is the key that slots into the BMW dash. It does have an emergency key inside it however but you have to pull it out. So is no good i'm afraid.
Post #51085 20th Feb 2011 10:52pm
dan_uk_1984
It is a BMW key to start with don't forget - circa 1991! But I see where you're coming from.
I think if done propperly it will be OK, obviously not glued together etc. It would have to feel nice and solid, as good as original.
Post #51087 20th Feb 2011 10:55pm
Nickj
Gazellio- agree generallly, but with my 2010 conversion think most buyers would be ok with it.
Dan -didn't notice that but wasn't really considering it anyway as key is in line 3 buttons and i think for easy conversion it would need to be a key with one above and two below, if you know what i mean!
Post #51089 20th Feb 2011 10:57pm
Nickj
oh, and any badgeing of orig brand would be removed of course Thumbs Up
Post #51090 20th Feb 2011 10:59pm
Nickj
Bought this key which comes with no branding and like shape/style.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWNX:IT
Will post once arrives.
Post #51983 26th Feb 2011 8:35pm
daveo
i, looks interesting, just bought the bmw diamond key V8 facelift Range Rover Autobiography 22" wheels.
Post #51984 26th Feb 2011 8:57pm
dan_uk_1984
Looks interesting, let us know how it turns out!
D
Post #51985 26th Feb 2011 8:57pm
Won't the pre-cut key blade be different?
Post #51990 27th Feb 2011 12:37am
Nickj
Key blade comes uncut. With the BMW diamond key how will you get over the fact on the RR key 2 buttons are side by side and one above, when on the bmw the 3 buttons are in line?
Post #52013 27th Feb 2011 4:26pm
Yes I know that I said "Pre-cut blade" what I meant was that if it is a Vauxhall rather than a Land Rover key fob the dimensions of the uncut metal blade will surely be different. Confused
Last edited by Gazellio @ Prestige Cars on 27th Feb 2011 7:26pm. Edited 1 time in total
Post #52039 27th Feb 2011 7:01pm
Nickj
See what you mean Embarassed Valid point. Will check dimensions when arrives. Thumbs Up
Post #52044 27th Feb 2011 7:20pm
If its the same width, depth & length I will be amazed......
Post #52048 27th Feb 2011 7:27pm
