![]() | Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140 ![]() ![]() ![]() |
Apparently not. From what I've read, double drop only gets 40-60% of the old fluid out... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
not really
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
My oil and filter was done about 3,000 miles ago if I do another drain is it worth doing the filter or should I do a double oil change and a new filter on the second one or just do a oil and filter change? |
if it was only done 3000 miles ago I personally wouldn't bother doing the filter again, just drop the oil once more and you will have swapped most of it. Bear in mind that the box oil will be in decent condition upto around 40000 miles. ZF only recommend changing it at around 60k if it is used for frequent towing, otherwise around 100km, so at 3000 miles the oil in there is still pretty much brand new. |
From what I've read out there on several different forums that use the zf6hp26 box, I think that figure's a little optimistic but I respect your opinion. Personally, I will be going down the full flushing route. It means more than twice the oil, but I can live with that. I have a suspicion that my TC is a little poorly and want to try fresh fluid before I rip it apart, but all the fluid has to be fresh and all the crap in the box needs to come out ![]() |
Okay, so I did the megaflush on the transmission today modifying my old sump as per the 5 series thread I linked to earlier. It took all 17 litres I had to do the flush and I could probably have done with another 5 litres to get it completely clean. That said, what was coming out at the end was pretty good.
So have finally got the correct amount of transfer box oil and changed it out.
mallet Member Since: 29 Oct 2022 Location: Manawatu Posts: 1 ![]() ![]() ![]() |
I am just in the thows of rebuilding my Range rover sport transfer box, had one failed bearing that has distributed itself through the box, my oil pump is tight , does not look like it comes apart , any idea if a replacement is available ?
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1004 ![]() ![]() |
JPAT here in the UK may be able to supply the pump. Their catalogue shows the pump (90), clip (91) and suction pipe (92) being available as a kit (K15).
gsmith1 Member Since: 13 Dec 2012 Location: Australia Posts: 6 ![]() ![]() |
My 2007 TDV8 DD295 Transfer Box is currently being overhauled, the bearings became noisy at around 40 – 70kmh so is now in the shop and seals, bearings, chain, oil pump, selector, clutch plates and clutch grips have been replaced.
Halim Member Since: 28 Dec 2023 Location: Terengganu Posts: 3 ![]() ![]() ![]() |
Hello Gents, anyone can help me locate an input shaft for the transfer box? I have contacted LR Direct but they don't have. |
JPAT & Sussex Autos (https://www.sussexautos.com/products/itc-p...&_ss=r) here in the UK, or Cobra Transmission (https://cobratransmission.com/itc-dd295-drive-shaft-55166021-1) in the USA.
Thanks Phil, really appreciate it.
Digger1970 Member Since: 30 Dec 2023 Location: ontario Posts: 1 ![]() ![]() ![]() |
Great write up. Just need to replace the input shaft.... can you just split and replace without removing all the motors etc. Trying to avoid any re calibration.... Thoughts? |
