Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 4 of 15 <123 45 ... 131415>
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I’m seriously thinking of carrying out this modification to my MY12 Westminster.
I’ve read this thread and others, and think I understand what I need, which is the radar unit, bracket and short cable and the later switch assembly (LR029647). I already have an IID tool.
The big question is, I’ve spotted a radar unit which has the number BH32-9G768 AC, the only difference being AC instead of AD.
Does anyone know if this is compatible?
Many thanks.
***** edited to correct typo and show correct part number (BH)
Post #511877 12th Apr 2019 8:06pm
GraemeS
Australia
I'm concerned at the BW32 rather than BH32 used in these vehicles as this indicates a different vehicle model. I don't know what vehicle uses the BW32 prefix but the one that I bought with CX23 prefix was from a Jag which had to have its firmware replaced with MY11/12 RR firmware before it would be recognised, presumably by the BCM.
Post #511885 12th Apr 2019 9:34pm
millerj90
GraemeS
Thanks for the speedy reply.
Sorry for the confusion caused by my typo. It is in fact BH
Post #511886 12th Apr 2019 9:43pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Ignore me, missed the point again Sad Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #511896 12th Apr 2019 11:27pm
GraemeS
Australia
Many thanks.
AC is the software version which is down-level from the latest AD version. It may need updating to the latest level but should still install and operate, unlike if the firmware is wrong as mine was whereby the radar unit wasn't recognised at all. My vehicle has several other modules which are not at the latest level but they still work, albeit probably with more bugs than the latest levels. Furthermore, if the AC is taken from a label then the module may have already been updated anyway.
Post #511899 13th Apr 2019 12:47am
millerj90
GraemeS
As always many thanks.
Order now placed Very Happy
Post #511907 13th Apr 2019 7:23am
GraemeS
Australia
Make sure that the radar unit has its 3 rubber mounting grommets.
The left switch bank is LR029644. The RH matching colour switch LR029647 is only required if your switches are the earlier grey rather than black versions.
Post #511912 13th Apr 2019 9:03am
millerj90
GraemeS
Many thanks for the tips. The module I’ve purchased comes on it’s bracket with the short cable attached. It looks like it has grommets on in the holes where the the fixings pass through on the way to the bracket.
I did try to post a photo, but I’m not having much luck with that at the moment.
I have a 2012 MY so I think the switches are the later "black" ones
Post #511961 13th Apr 2019 6:44pm
millerj90
Guys
All fitted and calibrated just as outlined in this thread. Works a treat! I'm still getting used to the braking effect (harshness) of "queue assist" and not sure if I actually trust it. But the follow mode is brilliant for what I need.
Only one problem to sort; similar to Nick Evans, I've lost the horn function on the new(LHS) switches so it look like I'm going to need the corresponding RHS switch is (LR029647). Even though the new and the old switches match in colour and my VIN is CAxxx.
This can wait for another day though
Many thanks to all that contributed to this thread, it made the job easy.
Best Regards
John
Post #513165 25th Apr 2019 4:29pm
GraemeS
Australia
Whilst I don't use braking to a stand-still, I like that emergency braking is active all the time even though the forward alert warning is occasionally triggered when I'm fully aware of a vehicle just ahead.
I assume that your switches are now slightly different colours but more than that, functionality is different too!
Post #513227 25th Apr 2019 10:28pm
millerj90
I might turn off the queue assist. It works ok, but just very jerky in slow moving rush hour traffic.
The switches look the same colour and all the functionality appears to be as it should I’m hoping that Nick can confirm that changing the RHS switch solves the problem.
I did look at the diagram and put my meter across the "old" switch, in the hope of resolving any pin-out changes. But further investigation into the switch pack itself reveals that it’s not as simple as one would’ve hoped.
I’ll order a RHS switch pack and hope that solves the problem.
Post #513228 25th Apr 2019 10:38pm
GraemeS
Australia
Disabling QA will mean that ACC drops out when the vehicle has slowed to 40 kph/25 mph IIRC so you could just cancel ACC as traffic slows so at least you are in control of when ACC disables rather than be informed that it has cancelled allowing the vehicle to roll on.
Edit: All MY11 switches changed starting with VIN BA349700. I hadn't spotted that earlier MY11 left switch including adaptive buttons is a different part number to the later adaptive switch.
The part number for the left ACC switch bank for MY11 up to BA349699 is LR023197, which does not supersede to the later switch without changing both switches. MY10 use different part numbers again.
Post #513231 26th Apr 2019 1:51am
millerj90
GraemeS
Once again your knowledge is invaluable, many thanks.
So I have the correct LHS switch LR029644, all I need is the corresponding RHS switch LR29647 Very Happy
Once again that you for all your help
Post #513241 26th Apr 2019 8:32am
GraemeS
Australia
The number for the RH switch to match with the latest LH ACC switch is LR029648 according to my late 2012 copy of Microcat, with LR029647 the matching RH switch for the latest manual CC LH switch. I had previously considered the latest RH switch to be the same switch for both ACC and manual CC LH switches. However I replaced only the LH switch in my MY12 yet everything works AFAIK but perhaps I should test that both horn buttons work, although I think that I would have discovered that one side doesn't work by now.
There are 2 steering wheel diagrams in Microcat referencing the switches, with the ACC version off the bottom of the screen so has to be scrolled up to be seen. I suspect that I had forgotten about the lower picture after my initial investigations and have incorrectly simplified the particular switches involved, although my RH switch is still the manual CC version which I assume is LR029647.
Post #513269 26th Apr 2019 1:02pm
millerj90
Post #513274 26th Apr 2019 1:11pm
