Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
I'm concerned at the BW32 rather than BH32 used in these vehicles as this indicates a different vehicle model. I don't know what vehicle uses the BW32 prefix but the one that I bought with CX23 prefix was from a Jag which had to have its firmware replaced with MY11/12 RR firmware before it would be recognised, presumably by the BCM. |
12th Apr 2019 9:34pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
GraemeS
12th Apr 2019 9:43pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Ignore me, missed the point again Current: 2011 FFRR Vogue SE 4.4 TDV8
12th Apr 2019 11:27pm |
AC is the software version which is down-level from the latest AD version. It may need updating to the latest level but should still install and operate, unlike if the firmware is wrong as mine was whereby the radar unit wasn't recognised at all. My vehicle has several other modules which are not at the latest level but they still work, albeit probably with more bugs than the latest levels. Furthermore, if the AC is taken from a label then the module may have already been updated anyway. |
13th Apr 2019 12:47am |
GraemeS
13th Apr 2019 7:23am |
Make sure that the radar unit has its 3 rubber mounting grommets.
13th Apr 2019 9:03am |
GraemeS
13th Apr 2019 6:44pm |
Guys
25th Apr 2019 4:29pm |
Whilst I don't use braking to a stand-still, I like that emergency braking is active all the time even though the forward alert warning is occasionally triggered when I'm fully aware of a vehicle just ahead.
25th Apr 2019 10:28pm |
I might turn off the queue assist. It works ok, but just very jerky in slow moving rush hour traffic.
25th Apr 2019 10:38pm |
Disabling QA will mean that ACC drops out when the vehicle has slowed to 40 kph/25 mph IIRC so you could just cancel ACC as traffic slows so at least you are in control of when ACC disables rather than be informed that it has cancelled allowing the vehicle to roll on.
26th Apr 2019 1:51am |
GraemeS
26th Apr 2019 8:32am |
The number for the RH switch to match with the latest LH ACC switch is LR029648 according to my late 2012 copy of Microcat, with LR029647 the matching RH switch for the latest manual CC LH switch. I had previously considered the latest RH switch to be the same switch for both ACC and manual CC LH switches. However I replaced only the LH switch in my MY12 yet everything works AFAIK but perhaps I should test that both horn buttons work, although I think that I would have discovered that one side doesn't work by now.
26th Apr 2019 1:02pm |
26th Apr 2019 1:11pm |
