Home > Technical (L322) > Suspension issues after towing
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I changed the compressor on mine and did not need a software update maybe because it was only pump that was changed and not the whole unit?
Post #512280 16th Apr 2019 4:27pm
Sandyt
Think you only need the software update if you upgrade the pump usually a change of manufacturer Thumbs Up
Post #512282 16th Apr 2019 4:31pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
You only need to change the firmware if you got from Hitachi/Dunlop to AMK compressor or vice versa.
When I swapped compressors earlier in the year I went for the Arnott AMK style one as it was cheaper than the going AMK from Land Rover.
Post #512289 16th Apr 2019 5:26pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I think my pump is fine, I watch it on the diagnostics on the way home last night and it was building up pressure no problem until it got hot and then cut out at 280f as it is supposed to do. The car then began to drop until the compressor had cooled to around 220f when it cut back in again.
Bag ordered from Dan yesterday afternoon and will hopefully fit it Thursday night so I have the car for the weekend.
I only ordered the bag (as mine is adaptive suspension and the whole strut is over £500!) Hopefully will come apart ok
Post #512335 17th Apr 2019 8:48am
Jamiehol
Does sound like the pump is ok given it shuts down at over temp and then cuts back in.
Fingers crossed it comes apart and goes back together ok.
Post #512341 17th Apr 2019 9:08am
L19 MUD
Yes fingers crossed. Not sure if I can get the bag off without taking the strut off the hub?
Never tried to remove a bag from a strut before but assume its just a case of removing the large centre nut like you would on a normal coil shock with the impact gun?
Post #512364 17th Apr 2019 12:46pm
You will have to remove the strut from the car to replace the airbag. .
Post #512372 17th Apr 2019 1:46pm
L19 MUD
Well it's off and would have been a doddle if the lower strut bolt wanted to come out! Anyway all ready to go back tomorrow when the bag arrives
Post #512448 17th Apr 2019 10:43pm
