Home > Maintenance & Mods (L322) > Unexpected bonus with the TDV8
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Maybe resolve that issue first and see how the engine feels / sounds after that ?? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #512783 21st Apr 2019 8:50pm
Andy
I’m wondering now if a faulty MAP sensor would cause the diesel knock. It doesn’t do it when cold. In fact it sounds awesome. As soon as I’ve covered a mile of so it starts rattling like a transit van! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #512784 21st Apr 2019 9:02pm
Nick591
What's the error code(s)? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #512791 21st Apr 2019 11:03pm
Andy
I'll check next time it faults 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514015 2nd May 2019 6:29pm
DrRob
Maybe get lads at Roean to look at it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #514043 2nd May 2019 9:57pm
Andy
I might do a smoke test to see if it’s leaking 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514046 2nd May 2019 10:32pm
Andy
Here's the fault.
Pat at GAP said it could be:
P023D-22 Manifold Absolute Pressure - Turbocharger/Supercharger Boost Sensor A Correlation - Signal amplitude > maximum
NOTE:
- Circuit MAP_A -
Intake air system fault
Turbocharger mechanical failure
Intake air temperature sensor failure
Mass air flow sensor failure
Manifold absolute pressure and temperature sensor failure
Exhaust gas recirculation sensor failure
Turbocharger actuator position sensor failure
Using the manufacturer approved diagnostic system perform the (Turbo, exhaust gas recirculation and air path dynamic test) routine
Check related DTCs and refer to the relevant DTC index
Refer to the electrical circuit diagrams and check manifold absolute pressure and temperature sensor circuit for short circuit to ground, short circuit to power, open circuit, high resistance
Check the intake air system. Check the turbocharger mechanical condition and operation. Check for DTCs indicating a listed sensor fault. Rectify as required. Using a data logger function, monitor the turbocharger actuator position and command the actuator to 5% pulse width modulated, then 95% pulse width modulated in 5% steps. Check the results. There should be a smooth curve between the minimum and maximum values. Check and install a new turbocharger. Clear DTC and retest
Refer to the warranty policy and procedures manual, or determine if any prior approval programme is in operation, prior to the installation of a new module/component 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517379 4th Jun 2019 9:02am
Nick591
Funny how often this fault comes up on bank A. I have never seen a post referring to this fault type for bank B. I wonder why?
There are a lot of posts and threads on here about this fault. Issues confirmed as causes range from split hose to split inlet manifold to stuck or sticking turbo linkage to suspect MAPT sensor to poor electrical connections Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #517435 4th Jun 2019 6:00pm
Andy
You mention sticking turbo linkages. I watched the drivers side turbo linkage when i turned the engine off and it moves from side to side but seems to stick momentarily and free itself whilst moving.
I hear a repeating squeak as well when its switched off which I assumed was coming from this linkage but when I stuck my head inside the arch it seems to be coming from higher up above the turbo.
I assume Bank A is the drivers side? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517440 4th Jun 2019 6:31pm
Nick591
Yes bank A is drivers side.
The turbo actuators go through an initialisation process when you switch on the ignition and again when you switch off the ignition. As you say you can see the drivers side one move, easier if you jack up front and take off the wheel. On mine the initialisation seems to go through a few actions which look a bit jerky but it also does move to both extremes of travel. With the ignition off and a suitable tool like a piece of stiff wire bent at the end you can move the linkage and should be able to feel if it appears to be stiff or binds at any point. If so get a spray can of 3in1 oil and use the tube to direct oil onto both pivots and either use the wire to move the linkage and free it off or cycle the ignition a few times. It is easest to see top pivot from under the car. I think the drivers side linkage is more exposed to road spray etc from wheel arch than passenger side. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #517464 4th Jun 2019 9:13pm
Andy
I took the front wheel off yesterday and got better access to the drivers side turbo
The linkage seems quite free and I can move it with my fingers to both extremes. I notice it doesn’t flick back in either direction though and if left, it will stay in the middle unless I move it with my finger. I sprayed GT85 on it and worked it up and down several times.
Lasted a day and bonged again today Evil or Very Mad
I guess the Indy will know more when he sticks it in his diagnostics. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517717 7th Jun 2019 7:36pm
Nick591
I still have 'unexplained bong' with that error code despite much effort to resolve (without major dismantling).
On mine it only seems to happen if I keep the throttle pedal in one position for more than about 2 or 3 seconds going up hills or when accelerating. I have got used to driving it under those circumstances with constant small variations of throttle position which is a bit of a pain but manageable. I wish I could eliminate the problem though. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #517774 8th Jun 2019 12:16pm
Andy
I could live with it if it didn’t keep shutting everything else down! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517775 8th Jun 2019 12:22pm
