![]() | Home > General > What Did You Do In Your Full Fat Today |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Sold it!
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1052 ![]() ![]() |
Swopped out the burnt solenoid contacks
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 142 ![]() ![]() ![]() |
Used Sport mode for the first time |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 439 ![]() ![]() ![]() |
Painted the back box.
Rude Member Since: 14 Apr 2019 Location: Knebworth Posts: 27 ![]() ![]() ![]() |
Cleaned 1,000,000,000 tar spots off it. The joy of white... |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
Replaced both rear discs, pads and shims on my Westie.
I’d love to be able to do maintenance like that. I’ve no clue though...!!!!!
Dropped the rear seats as flat as they will go, and then loaded the rear with "junk" from our sheds ready for a tip to the tip tomorrow.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
spent over an hour researching how to replace my reversing camera only to discover it was just caked in this Saharan sand / dust and a wet wipe sorted it |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 798 ![]() ![]() ![]() |
Up on the ramp, for oil change. Drainage container emptied and back on the stand for the last bit from the difficult to get to second sump nut...as the last bt dribbles in to container, knock it off the stand and watch as it hts the floor in slow motion. B@ll@cks !! Half a bag of soak it up later, job done. Change every 6 thous and its always like water. |
Past its mot |
Beninfrance Member Since: 25 Apr 2019 Location: Ladignac Le Long, Haute Vienne Posts: 8 ![]() ![]() |
Replaced the starter motor on my 2012 Westie.
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
Finished off three days 'fettling' of the front end - removed the 'orrible headlight grills (they were genuine LR - now in the bin along with the rears), rebuilt side-light units with stainless bolts for easier removal next time, replaced all headlight hardware with new clips and stainless bolts, fitted new air con condenser ready for a re-gas on Monday, fitted new bonnet release cable between the two catches, adjusted bonnet stops and started to give the bonnet a thorough clean with clay bar, G3 compound and paint restorer to remove a lifetime of oxidisation from it. There's actually a really deep silver hidden under the surface contamination! 2011 Range Rover Vogue SE 4.4 TDv8 |
