Home > Maintenance & Mods (L322) > Brake lines - how much
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
I've had the flexi hose rears replaced but I will need the entire brake lines doing. I've seen a guide (fantastic it was) but looks like a huge job! Has anyone had theirs done from an Indy or main dealer and if so, how much? What's everyne's experience with this common fault?
Something separate, I have quite spongy brakes atm. Any ideas on a possible cause or are they supposed to be like that? I'm thinking they might just need a bleed.
Post #515033 11th May 2019 11:31pm
Spongy Brakes - some options:
May need bleeding
New linings not yet bedded-in
Brake drums or discs badly worn or cracked
Master cylinder securing nuts loose
Wheel cylinder or caliper leaking
Master Cylinder leaking - bubbles in master cylinder reservoir
Brake pipe line or flexible hose leaking
Unions in brake system loose and leaking .
Post #515056 12th May 2019 9:40am
stuartj9
Joe, you're the fountain of knowledge. Cheers my friend.
Post #515067 12th May 2019 11:14am
Donimo
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Hi Stuart,
I had similar work done to my 2007 S/C last summer at MOT time - corrosion failure.
Replacing front to rear brake pipes, labour was £525.
I also have slightly spongy brakes according to the mechanic and he suspects the after-market rear calipers fitted to my car, to add to the list of your possible causes.
I use an independent LR/RR specialist. Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Past: 1968 LR 2.25 (petrol) Series IIa
Post #515073 12th May 2019 12:48pm
stuartj9
Cheers, Domino! I was thinking it would be around 400, so I wasn't far off. I've seen the guide on the wiki and tempted to have a go myself with the father in law.
Was yours replacing the hoses on the back too? I've had mine done and the cost for the parts was 90 from LR.
Post #515137 12th May 2019 9:51pm
Also, see this post about changing the front pipes (different for TDV8)
https://www.fullfatrr.com/forum/topic50421.html
(The howto wiki is all the same under the car / wheelarches, just the pipes in the engine bay, actually it is easier than a TD6)
Worth seeking a price for the two front pipes from Dan @ Duckworths if you do not fancy making up your own.
And change the front flexis as well. .
Post #515143 12th May 2019 10:20pm
stuartj9
Cheers Joe. The how to guide is about 3 days, which is fine.
When you say Dan @ Duckworths, I've seen this name before, do you mean he's on here or a website he has? Is he able to make up all the lines I will need and then buy the flexi pipes for the front from LR?
Post #515148 12th May 2019 11:57pm
Duckworths is an LR main dealer and forum sponsor (look in that section of the forum)
You can PM Dan who is the man ! (duckworthparts) .
Post #515150 13th May 2019 12:42am
