|  | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | I favour the updating of the radar unit to the latest s/w version but if your PCM version is back-level further than mine then it might also need updating. | ||
|  15th May 2019 8:46pm |
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 342      | So far so good.
|  16th May 2019 5:24pm |
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 342      | I'm still having a few niggles with this. The latest being "intermittent "Cruise Not Available", this appears to occur when ACC is bringing the car to a halt, and is proceeded by a "Driver Intervene" message".
|  20th May 2019 1:29pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Mine from mid last year.
|  20th May 2019 8:53pm |
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 342      | Many thanks GraemeS
|  20th May 2019 9:24pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Coming into urban areas I cancel CC the first time that traffic slows (usually traffic moving slowly entering a particular round-about) and don't use CC again until back into higher speed zones.
|  21st May 2019 6:54am |
| georgekale Member Since: 16 Jul 2015 Location: IL Posts: 22      |
 Did you ever get (Stop&Go) to work?  I recently installed ACC and going thru the same growing pains.
|  15th Sep 2019 5:26pm |
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 342      | GeorgeKale
|  15th Sep 2019 8:56pm |
| andyducati Member Since: 01 Sep 2017 Location: Eltham, Victoria Posts: 26      | I too am interested in retrofitting ACC to my L322.
|  21st Sep 2019 8:59am |
| georgekale Member Since: 16 Jul 2015 Location: IL Posts: 22      | Hi Andy, only one forward radar module required.  Photo enclosed.
|  21st Sep 2019 1:07pm |
| andyducati Member Since: 01 Sep 2017 Location: Eltham, Victoria Posts: 26      | Thanks georgekale,
|  25th Sep 2019 8:32pm |
| georgekale Member Since: 16 Jul 2015 Location: IL Posts: 22      | I have one for sale on E-bay.
|  25th Sep 2019 9:32pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Only 1 radar unit is used with the 4.4 but the 5.0 uses 2 so 1 may not work. The 5.0's 2nd requires a link cable between the 2. The 4.4's logic is in the ECM but the 5.0 in the L322 has its own module as already mentioned. | ||
|  26th Sep 2019 9:47pm |
| georgekale Member Since: 16 Jul 2015 Location: IL Posts: 22      | My 2011 5,0 Sc L322 works with only one radar unit shown. Also ECM controls the adaptive cruise. I seen the fish Illustrations showing rear CONTROL MODULE. But mine does not have it and an the adaptive cruise works. I have the radar module for sale. | ||
|  28th Sep 2019 11:35pm |
| Posting Rules
 Invalid data received from engine control module/powertrain control module - Algorithm based failure - signal is incorrect after the event.
