![]() | Home > Maintenance & Mods (L322) > Time to replace these rear dampers? |
| Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72
Yes
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
Very easy to replace, takes longer to access the three top bolts. My mechanic had them both done in under 20 minutes. Need to tip the rear seats forward to get to the bolts have a read here:
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
Just be careful that the axle doesn't drop when you undo the shocks or you'll end up with a torn airbag. |
| WB Member Since: 26 May 2016 Location: London Posts: 303
Thanks for all the replies.
Thanks for all the replies. It's quite a low mileage car (60k) but I'm keen to do preventative maintenance as it's coming up to MOT time at the end of the summer.
Prices vary due to active & non active suspension. |
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
The weep isn’t bad I.e not a MOT failure as they have to be weeping bad enough to either cover the shock body completely or lost enough fluid to effect the performance.
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
A good point from ur20v. My 2012 WM had weeping rear dampers from about year three, they were an advisory on the MOT, but not a fail. The dealer advice was to monitor them. They looked similar to yours. They did not really get any worse and were still on the car when it was traded in maybe eighteen months later (and working fine). So maybe get an expert view on MOT prospects (from someone not swayed by a desire to sell the parts or do the work) before replacing. Only Range Rovers since 1988 |
Thanks all, I'm going to keep an eye on them as it's a few months until MOT and see if they get any worse. |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 834
Interesting how the terminology changes with time.
Land Rover call it a damper in the work shop manual. My understanding is that as this is part of the air suspension system it doesn't work like a traditional shock absorber but in conjunction with the 'Air Spring'.
haha, yes, yes RR 2005 4.4 petrol
