![]() | Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
You do....smart key needs to be detected in the car and brake pedal needs to be pressed to start, in P or N.....
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Is there a fuel supply problem - not primed or tank level too low? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
The brake pedal will probably feel rock hard, making it difficult to engage starter until you get it started and build up some vacuum pressure.
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 ![]() ![]() ![]() |
Thanks, Baltic Blue. I've just seen that the starter motor breather tube is missing. I have no idea if its even possible to install without taking the engine back out. as I said at the beginning of this project nearly a year ago - its a jigsaw. When I said the engine is firing in my previous post; I made a mistake. they engine is turning. would the breather pipe not being connected stop it from trying to start? the brake pedal is not rock hard....not sure if that is a sign of something. |
biggirly1 Member Since: 21 Nov 2017 Location: Bicester Posts: 12 ![]() ![]() ![]() |
Have you power down trigger wire ?
The missing breather pipe on the starter won't stop it working and it's been turning anyway.
Any smoke from exhaust? Range Rover
That’s cracking news after all your effort.....onwards and upwards..... and all that....
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Amazing, congratulations you got it running!
Great that you got past the non-starting issue. Do you know if it was caused by the broken earth strap? |
