Home > Maintenance & Mods (L405) > Running a RR and saving money
supershuttle
I decided that the OEM JLR mats were lacking a bit so I bought BRITPART as recommended by Craig and palli as they cover more, particularly on the drivers side. I also thought what's the point of the recess in the boot if you have to fit the grossly overpriced OEM side net to make it useable, so I bought one from a chandlery for a few quid (I knew my days down a Cowes weren't wasted) I deliberately left the gap at the bottom so I can easily get the boot mat in and out. I used de-icer for the photo only - not much call for it in July rest of the stuff is the RSE headphones and a can of pop Rolling with laughter Rolling with laughter
 Geoff
Post #520736 5th Jul 2019 2:46pm
Looks good Thumbs Up
I reused my old L322 net -
I’m waiting for Stan to build an MDF one for his new toy Whistle
Post #520738 5th Jul 2019 3:04pm
you've got a good memory Alistair... Laughing
unfortunately i dont think it will work on the l405 as the floor section doesn't come up so that i can screw the mdf onto it, but fitting a net looks very easy...
@geoff , the mat looks good ..why dont they only do the fronts i wonder ... ... - .- -.
Post #520739 5th Jul 2019 3:13pm
Forward mounts are easy - getting backing washers onto the panel by the switches is a little more fiddly - Geoff has better locations due to a smaller net Thumbs Up
Post #520742 5th Jul 2019 3:24pm
supershuttle
FRONTS Shocked I only wanted the drivers side Geoff
Post #520745 5th Jul 2019 3:31pm
....and you ended up with a set of 4.. Laughing Wink
my drivers carpet one is rubbish..unlike your new rubber one which looks the puppys thingys... ... - .- -.
Post #520747 5th Jul 2019 3:34pm
supershuttle
Geoff has better locations due to a smaller net.
And I just used some very short self tapping screws, didn't think there might be electrics behind the panel and the eagle eyed will have noticed its a bit long. but if I do take it off the screws leave no trace in the carpet stuff. Geoff
Post #520748 5th Jul 2019 3:36pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Why didn't they just fit the same hooks each side as they did in the l322. Its like the sunglass holder (that's made it to the disco sport) that was dropped too and that's even more useful. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #520751 5th Jul 2019 3:53pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Is it Cam Tech Craig whose used a Ford sunglass holder?
Post #520754 5th Jul 2019 4:38pm
yes it was..its .in his range rover thread... ... - .- -.
Post #520755 5th Jul 2019 4:48pm
archermav
Post #520757 5th Jul 2019 4:50pm
Sunglasses holder thread Thumbs Up
Post #520761 5th Jul 2019 5:02pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Rolling with laughter Rolling with laughter have WD40 in mine would be lost with out it
Post #520778 5th Jul 2019 7:45pm
supershuttle
Actually the net slides up and down on the clips so I repositioned the top ones so now it reaches the bottom and I can raise it if I need to remove the rubber mat. Geoff
Post #521020 7th Jul 2019 10:49pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Where can i buy that net Geoff?
Thanks
Post #521400 10th Jul 2019 10:17pm
