![]() | Home > Maintenance & Mods (L405) > Running a RR and saving money |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3951 ![]() ![]() ![]() |
I decided that the OEM JLR mats were lacking a bit so I bought BRITPART as recommended by Craig and palli as they cover more, particularly on the drivers side. I also thought what's the point of the recess in the boot if you have to fit the grossly overpriced OEM side net to make it useable, so I bought one from a chandlery for a few quid (I knew my days down a Cowes weren't wasted) I deliberately left the gap at the bottom so I can easily get the boot mat in and out. I used de-icer for the photo only - not much call for it in July rest of the stuff is the RSE headphones and a can of pop |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8113 ![]() ![]() ![]() |
Looks good |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
you've got a good memory Alistair... |
@geoff , the mat looks good ..why dont they only do the fronts i wonder ...
....and you ended up with a set of 4.. |
Geoff has better locations due to a smaller net.
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 205 ![]() ![]() ![]() |
Why didn't they just fit the same hooks each side as they did in the l322. Its like the sunglass holder (that's made it to the disco sport) that was dropped too and that's even more useful. Current: RR L322 2010
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 356 ![]() ![]() ![]() |
Is it Cam Tech Craig whose used a Ford sunglass holder? |
yes it was..its .in his range rover thread... ... - .- -.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 617 ![]() ![]() ![]() |
Actually the net slides up and down on the clips so I repositioned the top ones so now it reaches the bottom and I can raise it if I need to remove the rubber mat. Geoff |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Where can i buy that net Geoff?
