![]() | Home > Maintenance & Mods (L322) > Transmission fault - some gears not available |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Yes a fault code reader is invaluable. Get the GAP IID BT, great support and lots of features including coding, logging and obviously fault code reading of of all modules. |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 ![]() ![]() ![]() |
Thanks. Do you have a link to one? From what I've looked for, are they around 500? Not sure I wanted to post that much though |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Do a gearbox oil and filter change no more than £150 max for this. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
You won't be using the correct oil at 150 quid cost more likely to be 300 to 350 |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
The iidbt is available from Dan at Duckworths for £405 and is well worth the expense. Saved me a good £250 so far in diagnostics and you can sell it on for a fair percentage of the initial cost. Also search GAP on here, wiki entry and their website for more info. Cheers Richard (there are no such things as an ordinary FullFat, an ordinary cat or too many tools) 2011 TDV8 Vogue Santorini Black Gap IIDBT |
This is my second car so don't really want to spend 400 on one just yet. Would the icarplay do the job? Has anyone used one?
