Home > Maintenance & Mods (L322) > Transmission fault - some gears not available
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
Hello, I have a TDV8 56 plate. I get the message above on the dash (or something really similar). The car seems to get stuck in 3rd gear. I only noticed as the revs were high after the message. I was unable to manually shift up or down but pulling over, turning the engine off and this seems to clear the fault.
I've had a read of the forum but can anyone suggest what it might be and what I should do? Do I need a code reader? If so, which one? I would prefer a decent one as I know I will probably use it quite a bit but don't want to pay huge money.
Post #521737 14th Jul 2019 10:10pm
ur20v
A Trap
Yes a fault code reader is invaluable. Get the GAP IID BT, great support and lots of features including coding, logging and obviously fault code reading of of all modules.
Post #521755 15th Jul 2019 8:30am
stuartj9
Thanks. Do you have a link to one? From what I've looked for, are they around 500? Not sure I wanted to post that much though Big Cry
Post #521760 15th Jul 2019 9:31am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Do a gearbox oil and filter change no more than £150 max for this. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #521761 15th Jul 2019 10:23am
dingg1
You won't be using the correct oil at 150 quid cost more likely to be 300 to 350
Post #521762 15th Jul 2019 10:25am
rjff
The iidbt is available from Dan at Duckworths for £405 and is well worth the expense. Saved me a good £250 so far in diagnostics and you can sell it on for a fair percentage of the initial cost.
Also search GAP on here, wiki entry and their website for more info. Cheers
Richard
Gap IIDBT
Post #521763 15th Jul 2019 10:30am
stuartj9
This is my second car so don't really want to spend 400 on one just yet. Would the icarplay do the job? Has anyone used one?
Looks like transmission oil will be getting changed. I think I have an invoice from when I bought the car with it bing done about 6 months ago. Wondering if it was actually done and the correct oil used.
Post #521845 16th Jul 2019 12:40am
