Home > Maintenance & Mods (L322) > Caravan lights |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Is your caravan 7 pin or 13 pin? |
16th Jul 2019 4:53pm |
killa Member Since: 23 May 2019 Location: birmingham Posts: 20 |
Does it matter that my car has led rear lights and the caravan has bulbs ? |
16th Jul 2019 4:54pm |
Twin 7 pin plugs and sockets |
16th Jul 2019 4:55pm |
It should not matter I have bulbs in my caravan changed from twin to single on the car to match the caravan Have you tried plugging your mate's caravan into your car? |
16th Jul 2019 4:59pm |
Friends car only has single electrics for trailer use |
16th Jul 2019 5:05pm |
Well if you have twin electrics 1 will be 7 pins the same as your mate's trailer and should work the same as your caravan the other plug is for running a fridge, charging caravan batterie. |
16th Jul 2019 5:25pm |
Yes the only thing that's not on with friends car was reverse lights which I believe are in other plug. |
16th Jul 2019 5:33pm |
Can you check the plug in the spare wheel area for corrosion? |
16th Jul 2019 5:45pm |
Just checked fuses.
16th Jul 2019 7:09pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
You have an earth problem and it's back feeding via other lights etc. Check inside the socket on the car, check the pins for corrosion etc. BMW i3 Electric Car
16th Jul 2019 7:11pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 343 |
Some cars do not recognise led trailer lights and require a modification to get them to work correctly. These issues are well known and a quick google of specific car/ year and caravan will give you the relevant fix. Generally it is the combination that causes the issue a different car will work the lights. Otherwise trailer light issues are generally earth problem related. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
17th Jul 2019 12:40am |
Been to autoelectrician today car wiring was all ok.
17th Jul 2019 8:13pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
GT85 is better (IMHO) than WD40.
17th Jul 2019 9:24pm |
You said "Plugged van into friends car all ok" so how could it have been the caravan plugs or have I understood it wrong? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
17th Jul 2019 10:03pm |
