![]() | Home > Maintenance & Mods (L322) > mot failure |
reynolds Member Since: 07 May 2010 Location: great yarmouth Posts: 83 ![]() ![]() ![]() |
hi my 2004 vogue has failed its mot on osf outer cv gaiter and rear hand brake efficiency what is involved is it beyond a competent home mechanic |
I hope they didnt test your HB on a rolling road:
thanks for your advise they did the brakes on the road i just wanted to know if you have the front air suspension de pressurised before removing the front hub to do the drive shaft boot thank you |
No need to de-pressurise the suspension, you'll need a 36mm bi-hex socket for the hub nut and removing the shaft from the hub will be very tight |
thanks for the advise much appreciated |
Dan,
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Thread now back in place |
Thanks Martin.
