![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
I’ll try and remember to plug in for a long journey soon too.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
I don’t know how to record iid readings other than taking screenshots whenever possible.
Is it not the red button top right to record? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Matt - any more yellow DPF lights since you had the work done and using it on longer runs than it was used to on the Isle of Man? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Rocket packs Matt.
Puts gearbox into neutral for recovery
EPB handbrake release lever is behind the right hand cover in boot if EPB won’t disengage. Usually because it’s not been adjusted on each service |
Matt,
Getting a little off topic? |
Been monitoring my regen miles 1.All city: 150 miles 2. 80/20 city/mway : 183 miles 3. 50/50 Today 205 miles. really mixed use 20/30/40/50 mph . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Better than yours Matt, not as good as Mike's...
Greg,
Matt - any updates? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
