Home > Technical (L322) > Restricted perfomance
Andy
The top hoses have been replaced with silicone. I’ve also had a smoke test done and found nothing apart from a hole in the air supply tubing to the turbo which I’ve also replaced. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527186 5th Sep 2019 10:27pm
cass
So the code shows a problem with the boost, you’ve got a remap which will likely have altered boost. If you are certain that there are no leaks on the boost side then I think the advice you were given by the tuner looks good.
I’m a dinosaur and generally not a fan of remaps, no doubt there are some excellent ones but there are also some poor ones and sadly it is often the “next” owners that face the problems
Post #527203 6th Sep 2019 8:35am
Andy
To be honest, I’m not bothered about a remap. I bought the car assuming it was standard. I’m sure the TDV8 is quick enough in standard form and my main priority is towing.
So how do I remove the map and put it back to factory? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527206 6th Sep 2019 8:49am
kbald
The PO23d code is normally a crack on the inlet manifold drivers side. A smoke test would normally show that up though. Unless it's only when it gets hot and the plastic expands. Try the soapy water test. Current 2007 TDV8 Vogue Buckingham Blue
Post #527221 6th Sep 2019 11:10am
Andy
Sometimes it faults as soon as I leave the work car park so I don’t think it’s down to getting hot and expanding. Then it won’t fault for days. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527223 6th Sep 2019 11:20am
Andy
Post #527224 6th Sep 2019 11:24am
cass
I would expect whoever you spoke to about the current remap would be the way forward to getting it set up with a standard map
Post #527247 6th Sep 2019 4:39pm
