![]() | Home > Maintenance & Mods (L322) > Electrical gremlins due to Light Control Module? |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672
So about 20 miles on it since I cleared the codes. These LCM codes have returned.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
These fault codes are to be expected and present no real impact on operation, according to GAP. .
Wife has the Beast today. If anyone can bring out a probably in a car it's her. I'll check codes again. |
The low headlight ignition faults are back. Any clue what can cause this? |
No. Probably put there intentionally so the British electrical gods don't think we have outgrown them. All hail Lucas. |
| landroverpoet Member Since: 08 Aug 2024 Location: Selfoss Posts: 6
So I have had very similar symptoms on my 2005 L322 The signals in the dashboard for the side flashers sometimes do not work and there is no sound (clicking sound), even though outside the actual flashers are working on the outside of the truck. It's like the dashboard doesn't even know that the side flashers have been activated. Then some minutes later a while after I made the turn and used the turn indicators, the dashboard indicator for the direction I chose earlier starts clicking away even though it's been minutes since it was selected - and no flashing is happening outside (since neither right nor left is selected when this happens) When stopping the car and shutting it off, the headlights and rear lights do not turn off. Quite annoying. But what always, always happens at the same time is that the head unit (main infotainment screen) becomes unresponsive. The orange light is not blinking, it is will be absolutely frozen. Either frozen off, on or in between. To solve this (temporarily) remove fuse 14 in the glove box and put it back in. This restarts the infotainment head unit, and everything else starts behaving as well. Until it happens again sometime later. I have no idea what is causing this. |
| All times are GMT |
