Home > Maintenance & Mods (L322) > Removing the shield to replace the inlet manifold. I'm stuck |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
See the wiki for egr replacement, you will need some extensions and universals .
14th Sep 2019 6:32pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Thanks Joe90 I've been following that post but that car is a left hand drive so the abs module is on the other side and more out of the way. You can't even see the final stud with the module in the way on the right hand drive car so can't even get a long extension socket in there. Current 2007 TDV8 Vogue Buckingham Blue |
14th Sep 2019 6:38pm |
What about from below, with a "sighter" in the engine bay guiding you ?
14th Sep 2019 10:28pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Sorry can’t help with this one as I haven’t done mine yet but just a heads up for when you get a bit further, a well respected local Landrover mechanic has told me that removing and replacing the rear injector requires a bit of not so gentle modification to the bulkhead and even then usually needs a new injector.
15th Sep 2019 7:51pm |
Does sound like a real pain if that's the case. Replacing the injector is going to add some big cost to the job though as they aren't cheap either. Current 2007 TDV8 Vogue Buckingham Blue |
16th Sep 2019 7:56am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Cant speak for LHD, but RHD to remove the tricky injector we just lifted the engine until it was clear? |
16th Sep 2019 9:51am |
Well I'm stuck. After loosing most of my tools and the nuts from the shield down in the engine bay it's all back together now to let someone else have a go. I can't seem to get to the last bolt and wondered how on earth I would ever get them back on anyway as that would seem impossible!
16th Sep 2019 11:46am |
Your experience has just convinced me to pay a professional to do mine for a few reasons,
16th Sep 2019 1:48pm |
Sounds like fair logic. The local indie to me is 10 miles away and it' might be a risk driving it there. I'm going to try mobile mechanic options or local garages but they may not have the knowledge to do it so I'm not sure how I will resolve it at this stage. Current 2007 TDV8 Vogue Buckingham Blue |
17th Sep 2019 6:46am |
Well I decided to have another go at the allusive hidden bolt today and finally got it out. Then manger to wrestle the shield out afterwards.
17th Sep 2019 6:17pm |
18th Sep 2019 6:14pm |
How, in the end, did you access and remove the elusive shield bolt?
18th Sep 2019 6:34pm |
In the end it was a case of long extension bars on a 1/4 ratchet with a woblle end on it and threaded it through the pipes from by the abs module before the ac pipes with a strong light from underneath to see the bolt.
18th Sep 2019 6:43pm |
18th Sep 2019 7:36pm |
