Home > General (L405) > 3ltr Diesel vs 4.4 sdv8 |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 215 |
Perhaps because with all those gadgets there’s a lot more to go wrong on an older car out of warranty = more costs? --
29th Aug 2019 7:57pm |
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 |
Do the new SDV6 models not have active suspension either?
29th Sep 2019 1:14am |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
I’ve been through the current brochures and spec. sheets and can’t find any reference to it in either car - which might even mean that neither now have it.
29th Sep 2019 8:55am |
Maybe it’s because many buyers swap their used cars more often that once every two years and the dealer (and hence the buyer) are having to pay for two years, yet only using one. I’ve crazily done that three times in seven years! |
29th Sep 2019 8:58am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2311 |
LR will not have started fitting conventional shocks to the L405 in place of the CVDs as the ride and handling with CVDs is far superior to that of conventional shocks. L405s have always been fitted with CVDs which started as standard fitment with the MY11 L322. |
29th Sep 2019 9:31am |
What are CVD’s? |
29th Sep 2019 10:04am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
sounds serious, Wikipedia says this,
29th Sep 2019 10:09am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
Continuously Variable Damper = Active suspension as it firms up when needed for cornering, but then eases off in a straight line to improve ride quality On the warranty question - I thought Approved Used always used to be 1 year - it only changed to 2 years around 4 years ago - so they must have had a noticeable negative impact to revert again |
29th Sep 2019 10:22am |
Gosh, little wonder they don’t fit it! |
29th Sep 2019 11:02am |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
So does my SDV6 |
29th Sep 2019 11:36am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
The difference is the hydraulic anti-roll system which isn’t fitted to the V6. |
29th Sep 2019 2:15pm |
It’s just not a standard fit, which makes it a bit of a pain to find if you’re looking for a used one |
29th Sep 2019 4:16pm |
It was standard on the Hybrid model, probably why they cost so much |
29th Sep 2019 9:17pm |
Even on the newer SDV6 ones? What is the LR speak for it as I can't seem to find it on the SDV8 or SDV6 L405s ? The only difference between the two engines is the active diff on the SDV8 |
1st Oct 2019 11:44pm |
