![]() | Home > Maintenance & Mods (L322) > First failure..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
Cheap fix we used years ago, take the cable off and tie a knot in it...!!!
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Pete!! Where have you been? apologies OP |
Rosco, PM me.. Pete
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 never use it |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
I can't agree that potentially having to rebuild a gearbox is preferable to maintaining and using a parking brake.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I agree with you Rich, I tend to use my handbrake as much as possible.
Driven automatics for 35+ years including hundreds of thousands of miles in police cars, never used the handbrake in an automatic, the parking pawl is much stronger than you think, it is designed to hold the vehicle on a very steep hill with a massive trailer on the back and then some....
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Thanks for your views folks. I’ll keep you posted as to how it goes. Car goes in this evening.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Yes but won't it create gap btw components? After a while it starts to make noise when put to D on hills. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
You put it in D when you are stationary then slowly release the brakes to let it rest against the pawl, only violent behavior will damage anything....!! Pete
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 616 ![]() ![]() ![]() |
nice to see you back pete |
OK, So handbrake mechanism replaced. It seems that the first half of the movement in the broken one didn't actually do anything. It was only the second half that actuated the shoes due to the broken cable tensioner. Lever action feels the same, but the handbrake now works. Still to test it on a REALLY steep hill though! |
