Home > Maintenance & Mods (L322) > First failure.....
Anvil
First failure.....
So, my car failed the MOT (Not unexpectedly) on the weak handbrake. (Cable operated). Shoes needed doing as did the discs, and pads, so I had the lot replaced. Was still unhappy with the handbrake as I had to use all my strength to yank it up in order to hold the car. So I took it back to the garage. Turns out that the cable tensioner (attached to the handbrake lever) is broken and cannot be any further adjusted so has to be replaced. You can't get the tensioner on its own apparently, just a handbrake kit. -Gonna cost me another £230 ish quid apparently. -Anyone else had this? -Is it a common failure? My search didn't turn up much unfortunately......
Oh, and while I'm at it, don't trust your range meter..... ran out of fuel the other day when I apparently still had 25 miles left to go........ Sad
4.2 S/C 06MY
Post #529677 1st Oct 2019 12:13pm
Cheap fix we used years ago, take the cable off and tie a knot in it...!!!
Handbrakes are next to useless when they are working correctly anyway, never used mine, just stick it in park..! Pete
-Click here for Thread-
Post #529707 1st Oct 2019 4:18pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Pete!! Where have you been? apologies OP Thumbs Up
Post #529712 1st Oct 2019 4:36pm
Rosco, PM me.. Pete
Post #529716 1st Oct 2019 4:45pm
Sandyt
+1 never use it
Post #529727 1st Oct 2019 5:52pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
I can't agree that potentially having to rebuild a gearbox is preferable to maintaining and using a parking brake.
A couple of tons against a relatively tiny piece of metal inside a very expensive moving parts case, rather than a couple of tons against a cheapish cable and very cheap designed brake shoes.
No brainer IMHO.
I always use the hand brake on all my cars auto or man, even the totally useless for 'hill starts' ML foot operated thing. (I don't have an extra foot).
Best Rich
Post #529735 1st Oct 2019 7:26pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I agree with you Rich, I tend to use my handbrake as much as possible.
Anvil, I replaced all the same as you, luckily after a lot of time adjusting it I have a fairly decent handbrake. Although I still have the dreaded ratchet slip some times. I'll be interested to see how you get on. Very Happy
Post #529737 1st Oct 2019 7:33pm
Driven automatics for 35+ years including hundreds of thousands of miles in police cars, never used the handbrake in an automatic, the parking pawl is much stronger than you think, it is designed to hold the vehicle on a very steep hill with a massive trailer on the back and then some....
Never heard of anyone braking a parking pawl on an autobox...
At the end of the day, do what you're happy with, the handbrakes are still c***..!! Pete
Post #529748 1st Oct 2019 8:32pm
Anvil
Thanks for your views folks. I’ll keep you posted as to how it goes. Car goes in this evening.
Cheers!
Post #529779 2nd Oct 2019 7:55am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Yes but won't it create gap btw components?
After a while it starts to make noise when put to D on hills. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529792 2nd Oct 2019 10:39am
You put it in D when you are stationary then slowly release the brakes to let it rest against the pawl, only violent behavior will damage anything....!! Pete
Post #529834 2nd Oct 2019 4:02pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
nice to see you back pete Thumbs Up
Post #529972 3rd Oct 2019 8:26pm
Anvil
OK, So handbrake mechanism replaced. It seems that the first half of the movement in the broken one didn't actually do anything. It was only the second half that actuated the shoes due to the broken cable tensioner. Lever action feels the same, but the handbrake now works. Still to test it on a REALLY steep hill though!
Post #530019 4th Oct 2019 10:54am
