Home > Technical (L322) > Advice on gearbox oil change, ZF 8HP70
ur20v
A Trap
Gearbox does self learn but normally after a oil change or flush the gearbox will be as before, with may be slightly different shift points but get progressively smoother from there as you add miles, you don’t normally go backwards on smoothness but it will operate slightly different.
Post #530544 11th Oct 2019 8:09am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I guess it should be softer.
At least mine was.. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #530546 11th Oct 2019 8:44am
rjff
ISTR somewhere on here reading of that the gearbox adaptations are sometimes reset by the guys doing the oil change and it leads to odd changes until the box learns your driving style.
Found it, page 2.
https://www.fullfatrr.com/forum/topic45466.html
Hope it helps. Cheers
Richard
Gap IIDBT
Post #530565 11th Oct 2019 11:09am
Clubman
Portugal 2011 Range Rover Vogue TDV8 Zambezi Silver
Greetings everyone
So update......
I've done around 900 km since the oil change. In higher gears, at road speeds, it is very smooth, you barely notice the changes. In town, specially when changing from 1st to 2nd, I is more abrupt, like on a old type automatic box.
is more noticeable when I start driving in the morning, when is hot is less pronounced .
For the moment, is not getting worse, so for time being, I'll just keep driving ,if it starts to get worse, then I will have to take it back to the ZF dealer.
the dealer did mentioned that it takes time for the gearbox to get used to the new oil ( their words ), I wonder if in reality is for the gearbox to learn how I drive ?
Post #530688 12th Oct 2019 7:05pm
