![]() | Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Greg - perhaps you could offer your DPF clearing service with your new box of tricks |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
@Greg,
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Hi Dolphin have you got any message on dash?
nothing. No faults or signs on the dash at all. |
Actually at 26g you are a knat's away from a RED:
Right,
Lucky break.
This is a null / not populated value Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 15th Oct 2019 9:54pm. Edited 1 time in total |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
My iid is the same version as Greg’s.
Just to add Dolphin, setting up the screen like mine so you can see those temps is essential, seeing above 600 is the only way to know it's actually happening.
BTW Your DTC code just means your DPF was saying it was full.
The field I have on my IID (and some others) is "Diesel particulate filter soot concentration - inferred using differential pressure". It appears that recent IIDs have this instead of an earlier field that was "Non Continuous Soot Mass" - as per Greg's screenshot above.
That's right DrRob, newer IIDs (or if you carry out the software update) have revised fields. I've not updated mine.
Rob,
