Home > eBay & Bargain Spots > ALDI 5 ton bottle jack |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 99 |
Just bought this gonna give it a try when I do the rear bushes. Got a 3 ton sgs trolley jack as well.
24th Oct 2019 5:39pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7736 |
Looks cheap enough
24th Oct 2019 6:48pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
Lifting range with load approx. 195-320mm
12th Nov 2019 4:45pm |
Still not got round to using it yet but will post once I can. 👍🏾 2004 Autobiography TD6 Java Black |
13th Nov 2019 9:34pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I saw this in Aldi and was tempted but I don’t think it will go high enough. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
21st Nov 2019 11:51am |
Used it today to aid in removal of rose joint bushes, it didn’t have the height to lift the car like my 3 ton sgs jack does. It helped lift the hub into place once I pressed out the old bushes and replaced, but the bottle jack was so slow at retracting back to normal height even with the release screws nearly all the way out.
2nd Dec 2019 10:48pm |
The oil might be thick so it won’t flow too well especially in the cold. Might get better with more use 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
2nd Dec 2019 10:55pm |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 |
What sort of lifting range do you need for these to be viable? Would be good to know when searching |
3rd Dec 2019 6:07pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
Search on here for the Sprinter jack. Lots about it and the mods for the FF. Cheers
3rd Dec 2019 8:59pm |
