Home > eBay & Bargain Spots > ALDI 5 ton bottle jack
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Just bought this gonna give it a try when I do the rear bushes. Got a 3 ton sgs trolley jack as well.
https://www.aldi.co.uk/compact-car-jack/p/099041307375000 2004 Autobiography TD6 Java Black
Post #532013 24th Oct 2019 5:39pm
Looks cheap enough Thumbs Up
It might be worth trying to fit a BMW mount on it like some did with the Sprinter jacks -
https://www.fullfatrr.com/forum/topic14177.html
Post #532024 24th Oct 2019 6:48pm
Make sure it has enough height to lift the wheels off the ground. Last one I bought from Aldi didn’t, despite being strong enough. Got - 2017 SDV8 Autobiography in Loire Blue
Post #532032 24th Oct 2019 8:06pm
Bingo_123
Lifting range with load approx. 195-320mm
dont think it will be enough, but do keep us posted.
Post #533936 12th Nov 2019 4:45pm
Swipe
Still not got round to using it yet but will post once I can. 👍🏾 2004 Autobiography TD6 Java Black
Post #534144 13th Nov 2019 9:34pm
Andy
I saw this in Aldi and was tempted but I don’t think it will go high enough. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #535005 21st Nov 2019 11:51am
Swipe
Used it today to aid in removal of rose joint bushes, it didn’t have the height to lift the car like my 3 ton sgs jack does. It helped lift the hub into place once I pressed out the old bushes and replaced, but the bottle jack was so slow at retracting back to normal height even with the release screws nearly all the way out.
It’s ok but would only use it as a secondary jack aid during maintenance.
Might have to look for something else to keep in car instead of the normal jack. 2004 Autobiography TD6 Java Black
Post #536203 2nd Dec 2019 10:48pm
Andy
The oil might be thick so it won’t flow too well especially in the cold. Might get better with more use 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536205 2nd Dec 2019 10:55pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
What sort of lifting range do you need for these to be viable? Would be good to know when searching
Post #536297 3rd Dec 2019 6:07pm
rjff
Search on here for the Sprinter jack. Lots about it and the mods for the FF. Cheers
Richard
Gap IIDBT
Post #536310 3rd Dec 2019 8:59pm
