Home > General > moving from disco's to Range Rover help would be appreciated
Page 3 of 3 <123
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Looks like the suspension fault may be the usual failure of wires wearing through on top of mountings as they look to be taped up, could be a simple fix, did you check it raised and lowered and no creaks or bangs and low corners? Restricted performance on a diesel I only have experience of this on a petrol Range rover L322 and that was an injector problem, on my wifes Discovery 4 the same issue came up and was a faulty air filter sensor that was a quick and easy fix.
There is plenty on here who will be better informed than me, but that may be a start.
Post #532710 31st Oct 2019 1:35am
Dolphinboy
Isn't that diesel a 3.6L TDV8?
Post #532732 31st Oct 2019 11:21am
davmonag
thanks drf. I did test the suspension. no creeks. all worked as it should apart from I put it into off road height and after 5 minutes it lowered itself. then the fault appeared. With all the input and help I have had on this I will not be going ahead with this one.
thanks again
David
Post #532812 31st Oct 2019 11:36pm
davmonag
it is indeed a tdv8.
Post #532813 31st Oct 2019 11:36pm
davmonag
purchase not going ahead
Hi all,
Thankyou for all your advice. I will not be going ahead with this purchase. to many questions without answers. I am looking at an owner on the forum plus a Rangerover down in Surrey. Hopefully let you all know by the end of the week which one I am going for.
getting excited. need to remain calm.
speak to you all soon
David
Post #532815 31st Oct 2019 11:38pm
davmonag
Hello All,
Well I m still looking. I did view a gorgeously smooth fast 5.0 AUTOBIOGRAPHY last weekend. ok it did require a few things to be done but then you expect that. first time driving a 5.0 lt petrol and wow. thats definitely a tick on my bucket list. Big Thank you Jamie. I am flying down to London on the 15th to view a 3.6 TDV8 vogue se. the main difference is the 5.0 petrol is a private seller and the 3.6 tdv8 is from a dealer with a warranty.
I will let you know what I find.
Post #533272 6th Nov 2019 12:33am
davmonag
Hi Guys,
Well this is the big day. Need to make a decision. Have flown south to look at 2010 tdv8 vogue se. Today i will be picking 1 of 3 i have now got my list down to.
Will update you all when the decision has been made.
David
Post #534431 16th Nov 2019 10:31am
DrRob
Good luck Thumbs Up
Dealers or private? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534439 16th Nov 2019 11:38am
davmonag
Hey, its a dealer. Just be brought in from a Landrover main dealer. 1 owner with FLSH plus the last service being a specialist.
D
Post #534440 16th Nov 2019 11:47am
davmonag
will these tyres / wheels fit my Range Rover?
Hi Guys,
To do some off roading I want to fit tyres and wheels originally purchased for my discovery 3. will these fit my 2010 Range Rover?
265-70-17. 118/121 Q BFGOODRICH or discovery 3 s alloys. see pictures below.
Post #537753 18th Dec 2019 12:02am
Page 3 of 3 <123
