Home > Technical (L322) > Reduced engine performance
Page 1 of 3 123>
Glibbs
4.2 SC
Been on the road for a couple of hours and then opened it up. Went up to around 4 thou, faltered and the engine light came on. Stopped and plugged in the iid and apart from some minor faults (DVD etc) there was no engine fault. Cleared all anyway - engine light out but still no power. Limped home (a couple of miles) and rechecked iid and still no engine fault.
Any ideas gratefully received.
Post #533386 7th Nov 2019 9:07am
DrRob
If you're nr Plymouth then Mark Kelly 4x4 Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #533388 7th Nov 2019 9:36am
Glibbs
I was yesterday but West Somerset today - thanks
Post #533404 7th Nov 2019 11:44am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Search Supercharger Coolant Pump on here and there's a wealth of info for you. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #533408 7th Nov 2019 12:29pm
Glibbs
Many thanks - perusing now. . . Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #533421 7th Nov 2019 2:49pm
Danwilderspin
I just changed mine as the restricted performance would bing cut power for 2 seconds and was fine again caught it early - you can get the Bosch pumps on amazon prime for under £100 fairly easy diy as long as you have light and good pliers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #533472 7th Nov 2019 11:58pm
Glibbs
Many thanks, have ordered a new pump and oil for the SC. Could you kindly give me an outline as how you changed your pump please? Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #533474 8th Nov 2019 12:02am
Danwilderspin
Of course in return when you do the oil tell me how much of the pita it is 😂 my charger bearings rattle when I had a misfire when it misfired I could hear it rattle now that seems to be mainly cured it’s stopped so thinking of doing oil to prserve it if not too much damage is done...
Anyway depending how flexible you are you can do it by unscrewing the bolt holding the washer fluid filler then dropping that as far right as possible.
Lift off the power steering responsive keep it mainly upright and dump as far right as possible.
Remove the front grill.
My personal tip as I spent an hour before I did this... out a glove on and wipe grease all around the two coolant pipes you have to remove.
Then with good plier squeeze the metal clips and lift as high as possible (they should glide on the grease otherwise they will dig in)
Pull them of and try to plug them or keep them facing up to save coolant.
Then there is a vertical slot where the grill was on the right. Get an 8mm socket and small ratchet in there and undo the bolt that holds the clamp around the pump to the side of the rad. Unfortunately the pump sits in a groove so you have to take it all the way out. The just lift it out.
Fitting it in reverse however I file the top of the pump with coolant first to make sure it was dry as little as possible. Also when you bleed it there is a bleed screw on top of the pipe at the top Of the pump take that out too and make sure it runs with no bubbles before putting in.
That ok for you? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #533490 8th Nov 2019 10:37am
Glibbs
That's super comprehensive, many thanks.
This the oil I've ordered for the supercharger: https://www.ebay.co.uk/itm/161492089065 Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #533499 8th Nov 2019 11:36am
Danwilderspin
Hi Gibbs how did you get on? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534011 12th Nov 2019 11:36pm
Glibbs
Hi,
Not too bad thanks.
The pump arrived yesterday so proceeded carry out your excellent instructions but. . . .
The new pump didn't come with a mounting bracket so I decided to remove the old one - big mistake!
The bolt sheared. So spent this afternoon removing the remainder of the clip. Ordered some M5 replacement clips so the pump is secured at the moment with a stainless steel cable tie. Ran the engine up and success. I will refit the air filter etc tomorrow and give it a run.
BTW an added complication is the the car is fitted with a bull bar.
TTFN Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534012 12th Nov 2019 11:50pm
Danwilderspin
Ouch!
My bracket Bolt was stiff but I just spayed the threads with some brunox and wound them back and forth until out. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534026 13th Nov 2019 8:35am
Glibbs
Think I must have been suckered into a false sense of well being as all the bolts etc on the SC have always come off without issue and I was only using a 1/4 inch drive. . . Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534051 13th Nov 2019 11:42am
Danwilderspin
I imagine it spilt coolant over the years eating away at it and salt from the roads getting to it hasn’t helped Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534057 13th Nov 2019 12:37pm
Glibbs
Put it all together and now 'Reduced etc'. Engine is at full temperature (iid 93deg) but the pipes to and from the pump are cold. Squeezing the pipes produces a reaction at the coolant filler but listening to the pump it sounds like it's cavitating. I've simply reconnected the electric cable as per original ie + to + should it be - to +?
Any other ideas gratefully received. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534096 13th Nov 2019 4:53pm
Page 1 of 3 123>
