Home > Technical (L322) > Reduced engine performance |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4234 |
If you're nr Plymouth then Mark Kelly 4x4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Nov 2019 9:36am |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 101 |
I was yesterday but West Somerset today - thanks |
7th Nov 2019 11:44am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 423 |
Search Supercharger Coolant Pump on here and there's a wealth of info for you. 2017 5.0 Autobiography Supercharged
7th Nov 2019 12:29pm |
Many thanks - perusing now. . . Range Rover 4.2 SC
7th Nov 2019 2:49pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
I just changed mine as the restricted performance would bing cut power for 2 seconds and was fine again caught it early - you can get the Bosch pumps on amazon prime for under £100 fairly easy diy as long as you have light and good pliers Current stable:
7th Nov 2019 11:58pm |
Many thanks, have ordered a new pump and oil for the SC. Could you kindly give me an outline as how you changed your pump please? Range Rover 4.2 SC
8th Nov 2019 12:02am |
Of course in return when you do the oil tell me how much of the pita it is 😂 my charger bearings rattle when I had a misfire when it misfired I could hear it rattle now that seems to be mainly cured it’s stopped so thinking of doing oil to prserve it if not too much damage is done...
8th Nov 2019 10:37am |
That's super comprehensive, many thanks.
8th Nov 2019 11:36am |
Hi Gibbs how did you get on? Current stable:
12th Nov 2019 11:36pm |
Hi,
12th Nov 2019 11:50pm |
Ouch!
13th Nov 2019 8:35am |
Think I must have been suckered into a false sense of well being as all the bolts etc on the SC have always come off without issue and I was only using a 1/4 inch drive. . . Range Rover 4.2 SC
13th Nov 2019 11:42am |
I imagine it spilt coolant over the years eating away at it and salt from the roads getting to it hasn’t helped Current stable:
13th Nov 2019 12:37pm |
Put it all together and now 'Reduced etc'. Engine is at full temperature (iid 93deg) but the pipes to and from the pump are cold. Squeezing the pipes produces a reaction at the coolant filler but listening to the pump it sounds like it's cavitating. I've simply reconnected the electric cable as per original ie + to + should it be - to +?
13th Nov 2019 4:53pm |
