Home > Maintenance & Mods (L322) > DPF regeneration |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
The DPF themselves rarely go wrong. There are a few instances of people blaming a DPF fault like this guy:
11th Nov 2019 9:14pm |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
1. Fuel dilution, highly possible due to car possibly not being serviced in a while. Not sure why diesel should be contaminating the oil though
12th Nov 2019 8:05am |
Range Rover L322
12th Nov 2019 8:14am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
Fuel dilution into the crankcase oil can occur because the car pumps diesel into the dpf to raise temps in order to regen. My level was 12 it after oil change is now reading 0.082. |
12th Nov 2019 11:03am |
Cheers Dolphinboy, was curious as to why diesel would get into the oil |
12th Nov 2019 11:47am |
I have had my car back for a couple of weeks now. Garage were unable to force a regen of the DPF due to it being pretty much full to the brim, so they cut off the relevant exhaust section and carried out a clean before refitting. I left it with them for a few days to run around in to test everything was OK and am happy to report that everything is working exactly as it should.
27th Nov 2019 4:35pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
Good to hear it's all fixed. Be good to know name of garage for sake of others in your area 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Nov 2019 4:50pm |
Simon Huntingdon in Wigton Cumbria. One of the best independents I have used over the years. |
27th Nov 2019 4:53pm |
well just had to bite the bullet and get the pax side inlet manifold changed (they change the plenum pipes for the new design as part of the package.)
26th Mar 2020 7:14pm |
Aman Member Since: 26 Jan 2021 Location: West Midlands Posts: 5 |
Guys I have experienced 2 full dpf red warnings, car went into restricted performance. Turned out to be a faulty erg temperature sensor fault, luckily this sensor is easy to get to. Ever peachy until yesterday due to local short trips the Red DPF FULL IN RED returned. Went to my local garage..error code P2463...soot accumulation. Went for a blast to try and regen but nothing..40 mile round trip at high revs using paddle shift. I then bought Wyns DPF cleaner for a tenner..went for a blast again and it's now cleared..car drives beautifully...give it a go before paying someone . |
26th Jan 2021 3:04pm |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 142 |
Sorry for the thread resurrection but I’ve been trying to check my DPF level with my GAP IID but the PCM module isn’t shown on the live values quick list, I can’t find any guidance about how to get to those soot mass readings. I’ve had the tool plugged in, connected to my phone with the engine running, and also with just the ignition on. Nothing.
29th Jun 2023 6:02pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2675 |
What you are doing wrong is checking it if there is nothing wrong woth it......... 2012 TDV8 Vogue (L322) |
29th Jun 2023 6:14pm |
Gee. Thanks Gee.
29th Jun 2023 6:16pm |
PCM?
29th Jun 2023 7:07pm |
