![]() | Home > Off Topic > Spline repair brass ? Tip pls! SOLVED |
I would be inclined to clean up the splined shaft and inside of the brass cap and then use araldite to glue the cap in place so that it is located correctly and solid. Then drill a 3mm día hole through the side of the cap passing through the shaft and out the other side. Then cut an M3 stainless steel bolt to the día of the brass cap removing the head end and push it into the hole and finally fit the handle over.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Like your thinking nicedayforit!
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
How about cleaning up the splines and coating them with chemical metal, then putting the knob back on to take the pattern of the splines?
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1571 ![]() ![]() |
Replace the shaft and valve. Unscrew it, and screw in a new one. They should be readily available at a plumbing supply store. Ron B. VK2OTC
Thanks Mike. |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
I have the same unit as pictured, and also had the same problem, for the two days waiting for the part to arrive i just popped a small mole grip on the splines and operated it that way. |
I was just going to suggest Vise-Grips* (Mole Grips). |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6423 ![]() ![]() |
For temp fix, wrap the splines in PTFE tape or similar (plastic bag?) for a "press fit" .
Sorted till the part arrives!
Proper job |
You could always have a bath instead! |
