Home > Off Topic > Spline repair brass ? Tip pls! SOLVED |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I would be inclined to clean up the splined shaft and inside of the brass cap and then use araldite to glue the cap in place so that it is located correctly and solid. Then drill a 3mm día hole through the side of the cap passing through the shaft and out the other side. Then cut an M3 stainless steel bolt to the día of the brass cap removing the head end and push it into the hole and finally fit the handle over.
29th Nov 2019 10:46pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Like your thinking nicedayforit!
29th Nov 2019 11:06pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
How about cleaning up the splines and coating them with chemical metal, then putting the knob back on to take the pattern of the splines?
29th Nov 2019 11:08pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Replace the shaft and valve. Unscrew it, and screw in a new one. They should be readily available at a plumbing supply store. Ron B. VK2OTC
30th Nov 2019 2:43am |
Thanks Mike. Hadn't thought of chemical metal. Just have to figure out how to fit the cap to hold the shaft, without it sticking. Maybe cling wrap.
30th Nov 2019 9:59am |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
I have the same unit as pictured, and also had the same problem, for the two days waiting for the part to arrive i just popped a small mole grip on the splines and operated it that way. |
30th Nov 2019 10:35am |
I was just going to suggest Vise-Grips* (Mole Grips).
30th Nov 2019 1:09pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
For temp fix, wrap the splines in PTFE tape or similar (plastic bag?) for a "press fit" .
30th Nov 2019 1:22pm |
Sorted till the part arrives!
30th Nov 2019 2:52pm |
Proper job Won't need a new one now .
30th Nov 2019 5:24pm |
You could always have a bath instead!
30th Nov 2019 8:20pm |
