![]() | Home > Technical (L322) > Fuel sender 2 and rear passenger window |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Andy,
| andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 104
Excellent cheers I will take a look and see if that works at weekend cheers |
| Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 176
What's the difference between a tsb and a recall?
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
A recall relates to an issue endangering life? A TSB is just a way for the manufacturer to communicate common issues and their resolution to the field in a structured way. 2016 Skoda Octavia VRS Estate
Andy
Great even more water problems I bet,I will take off both door cards and get some new clips because my luck is they will brake off I have the trim tools already Thank you for the pointers |
I know this concerns a tailgate, but the idea of a chafed wire in the ducting/gaiter may be worth a look if you don't find corrosion from water ingress
Cheers rjff that could be a possibility as before you could hear the relay keep clicking as if something was earthing when you went over bumps before |
Well fuel pump sorted gauge back.i replaced original pump with a genuine bmw one and put it back together doing that modification of chopping plugs and hard soldering the joints and it’s all working great now cheers Richard just got the windows to sort now when we get a dry day |
Great you got the fuel system sorted. |
| Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180
Both my rear windows stopped working.
Well took apart the door to check see what’s up with the window and tested everything and got it down to the switch so looks like I will have to give rangerover a ring Monday and see how much they will sting me for a new one thanks guys for the heads up on everything very much appreciated |
