Home > Maintenance & Mods (L322) > New/refurbished engine subframe
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi,
Had the beast (td6 2002) in the mechanics after which I was informed I'm going to need a new engine subframe due to corrosion. Anyone have an idea about part numbers or where best to source this?
Anyone experience in changing this part?
Post #539797 8th Jan 2020 9:22am
ur20v
A Trap
Are you sure, in the salty UK these can look very corroded but actually ok, it’s normally surface scale and when cleaned off very little wall loss is found. The tubing is very thick walled.
Post #539803 8th Jan 2020 10:29am
Teaspoonasaurous
I'm just going on what the mechanic told me! He said it would fail the MOT based on corrosion. I might let it fail and then replace
Post #539805 8th Jan 2020 10:31am
dingg1
Get under there and get it scraped and make up your own mind.
Probably not much wrong after a good going over with a scraper and a bit of rust killer on it.
Post #539811 8th Jan 2020 11:25am
Teaspoonasaurous
That's the weekend sorted!
Put it extended mode, scraper and rust killer?
Post #539827 8th Jan 2020 1:02pm
+ axle stands. Wink Thumbs Up
Post #539829 8th Jan 2020 1:35pm
DrRob
Post some pictures and we can advise if you want.
I would suggest a wire brush, some cure rust then smooth rite paint Thumbs Up
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539836 8th Jan 2020 5:06pm
mjdronfield
When I bought my TD6, the garage had to sort the subframe. Ended up on a ramp with steering off etc and engine supported, whilst it was sent off for clean up and powder coating.
Was advised on previous MOT, so I said I wasn’t buying without it sorted.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #539841 8th Jan 2020 6:22pm
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
Is this that part you need ?
I have the same problem I must change my subframe
Regards
Frank
Post #539844 8th Jan 2020 7:58pm
Danwilderspin
This is common they are rust buckets.
I just sold my 02 to a breaker as it had started to go, the rear subframe would t pass the next mot and the sills has gone too - please check these before investing too much!
I’m talking you could poke holes in some bits (my arches were like his too)
Ironically it always had a slow oils leak which kept coming back so my front subframe was like new just oily Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #540362 12th Jan 2020 9:41pm
FrankN
I had the subrame sandblasted and re-coated, I just have to install it
Frank
Post #540428 13th Jan 2020 12:41pm
FrankN
Re: New/refurbished engine subframe
Teaspoonasaurous wrote:
Hi,
I have yesterday build out the subframe , it´s not so easy , I have a heavy rust cleaner the first two days spray every day
here is a picture from the old subframe
here you see what parts yo must rebuild
and this little part, the exhauster from the heather is the mistake , it is too short , 5 cm longer and I have not must change the subframe Neutral
Post #545661 1st Mar 2020 2:03pm
