Home > Maintenance & Mods (L322) > New/refurbished engine subframe |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Are you sure, in the salty UK these can look very corroded but actually ok, it’s normally surface scale and when cleaned off very little wall loss is found. The tubing is very thick walled. |
8th Jan 2020 10:29am |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 |
I'm just going on what the mechanic told me! He said it would fail the MOT based on corrosion. I might let it fail and then replace |
8th Jan 2020 10:31am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Get under there and get it scraped and make up your own mind.
8th Jan 2020 11:25am |
That's the weekend sorted!
8th Jan 2020 1:02pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
+ axle stands. |
8th Jan 2020 1:35pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
Post some pictures and we can advise if you want.
8th Jan 2020 5:06pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
When I bought my TD6, the garage had to sort the subframe. Ended up on a ramp with steering off etc and engine supported, whilst it was sent off for clean up and powder coating.
8th Jan 2020 6:22pm |
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 |
Is this that part you need ?
8th Jan 2020 7:58pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
This is common they are rust buckets.
12th Jan 2020 9:41pm |
I had the subrame sandblasted and re-coated, I just have to install it
13th Jan 2020 12:41pm |
I have yesterday build out the subframe , it´s not so easy , I have a heavy rust cleaner the first two days spray every day here is a picture from the old subframe
and this little part, the exhauster from the heather is the mistake , it is too short , 5 cm longer and I have not must change the subframe
1st Mar 2020 2:03pm |
