Home > In Car Electronics (L322) > Rear dash cam - Garmin Mini - an experiment
DrRob
Going to experiment rigging up a small, discrete upper tailgate mounted, rear facing dash cam....
On its way....Garmin Dash Cam Mini Key-Sized Dash Camera with 140-degree Wide-angle Lens and Recording in 1080p HD Video https://www.amazon.co.uk/dp/B07RB4WKSC/ref...cEbXXWSACC
Short term, will power from boot cigarette lighter that is ignition live.
Long term, will wire into an ignition live rear fuse box ...if it exists.... Whistle
Any advice welcomed Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539021 31st Dec 2019 4:48pm
DrRob
Any body know if there is am ignition live fuse in boot that I can piggy back off? 2011 car.
Post #540030 10th Jan 2020 10:59am
i wired mine up to the rear of the power socket in the back Rob...my socket went off with the ignition so it was ideal.. ... - .- -.
Post #540031 10th Jan 2020 11:12am
DrRob
May I ask how you do it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540034 10th Jan 2020 11:43am
open the offside panel, stick your hand behind the socket and depress the metal bits and push/pull/wiggle the socket out..you then have the wires exposed and then tap into the wires.. ... - .- -.
Post #540038 10th Jan 2020 1:10pm
DrRob
Post #540049 10th Jan 2020 2:57pm
Poprivit
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
be interested to see how you get on. I have a rear mounted install in mine that is not HD due to the age of it. may look at this on mine once its a bit warmer.
Post #540057 10th Jan 2020 4:30pm
DrRob
Camera is rigged temporarily onto upper tailgate and recording nicely. Need to reposition and maybe buy the polarising filter to reduce glare. Cable routing is work in progress but currently runs along top of C pillar trim, along bottom of window, across into boot, down one side, under rubber mat and up the other side into ciggy lighter. Done like this as camera needs to be in sweep of wiper blade. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540542 14th Jan 2020 11:06am
Poprivit
What’s the image quality like?
Post #542740 2nd Feb 2020 10:20am
DrRob
Yes. Interact and download via the app. It looked Censored in the back window so moved it to my Classic instead. Nice little compact camera for sure Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542752 2nd Feb 2020 12:02pm
GGDR
I've got a rear cam but I didn't want to see it so I fixed it bottom left in the rear tailgate glass, positioned so in my rear view it's hidden by rear seat headrest. Just didn't want to spoil the rear view.
Cable is 100% hidden, runs behind the tailgate plastic trim, through the original rubber boot / gator then under the headliner and down the pillar eventually to the centre console where I have a USB power hub thing.
Same cam on front, they are from Amazon so I guess Chinese 1080p, 170 degree view with a micro SD card. Seem good enough as sentries. Cost around £55 each.
What I would like is the cams running constantly i.e. after I lock the car and overnight but have not ben successful with power supply.
I noticed Charles89 says he runs his for days off the main battery.
. Cheers, Greg
Post #542756 2nd Feb 2020 12:24pm
DrRob
You can now get stand alone power packs to do exactly that Greg Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542758 2nd Feb 2020 12:30pm
GGDR
So I bought a 'pass through' power pack that can be left charging and run power at the same time.
So this runs the 2 camera for a good few hours...
But my short commute doesn't last long enough to charge the power pack to full.
Once I get to work then I leave the car all day again. The power pack, only now on around d 20% drains out quickly and so I haven't found the right solution yet.
Any tips?
. Cheers, Greg
Post #542766 2nd Feb 2020 1:15pm
Poprivit
i have been thinking about a solar panel and use this with an aux battery. What battery did you fit?
Post #543010 4th Feb 2020 5:34pm
GGDR
I tried two different USB power packs that support 'pass through' charging
(which is charge and draw at he same time).
Like the idea of solar. Thumbs Up
. Cheers, Greg
Post #543032 4th Feb 2020 9:37pm
