![]() | Home > In Car Electronics (L322) > Rear dash cam - Garmin Mini - an experiment |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Going to experiment rigging up a small, discrete upper tailgate mounted, rear facing dash cam....
Any body know if there is am ignition live fuse in boot that I can piggy back off? 2011 car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35793 ![]() ![]() |
i wired mine up to the rear of the power socket in the back Rob...my socket went off with the ignition so it was ideal.. ... - .- -.
May I ask how you do it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
open the offside panel, stick your hand behind the socket and depress the metal bits and push/pull/wiggle the socket out..you then have the wires exposed and then tap into the wires.. ... - .- -.
Camera is rigged temporarily onto upper tailgate and recording nicely. Need to reposition and maybe buy the polarising filter to reduce glare. Cable routing is work in progress but currently runs along top of C pillar trim, along bottom of window, across into boot, down one side, under rubber mat and up the other side into ciggy lighter. Done like this as camera needs to be in sweep of wiper blade. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Poprivit Member Since: 11 May 2014 Location: East Yorkshire Posts: 27 ![]() ![]() ![]() |
What’s the image quality like? |
Yes. Interact and download via the app. It looked |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
I've got a rear cam but I didn't want to see it so I fixed it bottom left in the rear tailgate glass, positioned so in my rear view it's hidden by rear seat headrest. Just didn't want to spoil the rear view.
You can now get stand alone power packs to do exactly that Greg |
So I bought a 'pass through' power pack that can be left charging and run power at the same time.
i have been thinking about a solar panel and use this with an aux battery. What battery did you fit? |
I tried two different USB power packs that support 'pass through' charging
