![]() | Home > Maintenance & Mods (L322) > Good day: fitted new battery. Bad day: found oil leak(s)... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Did you check the oil cooler and associated pipe for leaks? Easy to see when air box is off. Stand on a box and peer down the back of engine and look forwards ...so to speak. If it looks like this then oil cooler gaskets need doing.
If no leak then it will be bone dry like the second image further down this thread
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 423 ![]() ![]() ![]() |
Thanks DrRob,
It’s tricky to get mark 1 eye ball on the oil cooler and pipe. I used a small step to get higher, a little mirror to peer down and forwards if that makes sense |
I read the 21-Page leak thread in the wiki, actually feel confident about tackling it.
It’s red trans oil, a whole load tonight leaking out, not from the pan but around the bell housing.
Yep. Have you got a decent place locally?
I’m half way up a mountain in Spain...lol
