Home > Maintenance & Mods (L322) > Good day: fitted new battery. Bad day: found oil leak(s)... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Did you check the oil cooler and associated pipe for leaks? Easy to see when air box is off. Stand on a box and peer down the back of engine and look forwards ...so to speak. If it looks like this then oil cooler gaskets need doing.
12th Jan 2020 8:02pm |
If no leak then it will be bone dry like the second image further down this thread
12th Jan 2020 8:05pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 391 |
Thanks DrRob,
12th Jan 2020 8:07pm |
It’s tricky to get mark 1 eye ball on the oil cooler and pipe. I used a small step to get higher, a little mirror to peer down and forwards if that makes sense 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
12th Jan 2020 8:10pm |
I read the 21-Page leak thread in the wiki, actually feel confident about tackling it.
12th Jan 2020 8:20pm |
It’s red trans oil, a whole load tonight leaking out, not from the pan but around the bell housing.
13th Jan 2020 8:18pm |
Yep. Have you got a decent place locally?
13th Jan 2020 8:50pm |
I’m half way up a mountain in Spain...lol
13th Jan 2020 9:05pm |
