Home > Technical (L322) > Window Drivers-side L322 Wont Close |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3063 |
Take the Door card off and examine the window regulator. The wire that rotates and pulls the window up and down can shear off if there is a sudden jerk or its gets stuck/kinked. or it can come off the pulley at the bottom.
16th Jan 2020 1:31pm |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
Thanks for info buddy or should I say mon ami
16th Jan 2020 1:54pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
A few bits to help on the door card removal.
16th Jan 2020 2:16pm |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
Exactly the same happened with mine, regulator wire frayed and got clogged up , new regulator fitted.
16th Jan 2020 2:31pm |
Thanks for that, very helpful, mine was first registered 30 June 2002 so very early model, V8 SE (Poverty Pack) on LPG, otherwise factory original.
16th Jan 2020 2:33pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7638 |
You could try holding the lock button down on the fob, and see if total closure feature closes it....will take switch out the equation.....
16th Jan 2020 3:01pm |
Good call and yes I did try that and... drivers window stayed fully down whilst the other three obediently raised... that outcome plus the fact that the drivers window switch was able to lower the window does point to something more mechanical like a broken regulator cable I guess. So plan of action is: 1 - Get battery reconnected in a fully charged state tomorrow/weekend once wheels are back on. 2 - Get IID Tool configured and run a full fault scan plus see if it will allow me to attempt a manual over-ride window raise? 3 - If 2 fails, then remove door card and have a poke around! Something else that occurs is I believe the window mechanism has some anti-trap functionality and I'm wondering if so then is there a sensor that governs this which might have gone rogue, or am I barking up the wrong tree? What a pain in the a***, such a simple thing but make the beast unusable, hey ho. |
16th Jan 2020 4:05pm |
Anti trap would make the window automatically go down to about 2 inch above fully down, so I don’t think it’s that.
16th Jan 2020 4:12pm |
