![]() | Home > Maintenance & Mods (L322) > Suspension down on one side |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Fault codes read? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
Yesterday it was read.. was saying abs sensor rear right, but we have just replaced the sensor, so im told to buy an abs ring now.. but today, the suspension is down on one side, I haven't had it read again.. it costs ££ every time someone looks at it |
Here's the codes from the scan yesterday..
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 543 ![]() ![]() ![]() |
I wonder if you might have a broken wire / damaged loom which has affected the ABS. In the meantime, get yourself a code reader to save some £££.
Are you near Dundee? Take it to MMP Land Rover. Disco Mikey on here |
Thanks Mike.. I just joined and pm'd the chap.
I was tempted at that price and I already have the earlier version and an IID BT |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
Snap!. Came out to the same thing 4 days ago. When I start it up it pumps itself up and drives ok but overnight the front passenger side slumps.
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
I had a suspension warning whilst on the M3 last Saturday, and woke up to exactly the same picture (albeit in Stornoway Grey) the following day, front passenger side slumped!
Wow.. ok thanks for this |
Mine were for a 2011 5.0 S/C with Adaptive Dynamics, if you are the 2007 TDV8 listed in your profile then you get to use the cheaper struts without the Adaptive bit |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Same story with mine so both front struts getting replaced Monday all being well.
Yes, although given the springs are basically made of rubber, I'd consider them a wearable component anyway, and would prefer to replace them than many other things on the truck!
Thank you Paul for that comprehensive post, this is very helpful, thanks! 2010 FF 4.4 TDV8 Vogue - Gone
