Home > Maintenance & Mods (L322) > Suspension down on one side |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
Fault codes read? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Jan 2020 4:08pm |
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 |
Yesterday it was read.. was saying abs sensor rear right, but we have just replaced the sensor, so im told to buy an abs ring now.. but today, the suspension is down on one side, I haven't had it read again.. it costs ££ every time someone looks at it .. 2010 FF 4.4 TDV8 Vogue - Gone
18th Jan 2020 4:12pm |
Here's the codes from the scan yesterday..
18th Jan 2020 4:27pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
I wonder if you might have a broken wire / damaged loom which has affected the ABS. In the meantime, get yourself a code reader to save some £££.
18th Jan 2020 4:49pm |
Are you near Dundee? Take it to MMP Land Rover. Disco Mikey on here 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Jan 2020 5:37pm |
Thanks Mike.. I just joined and pm'd the chap.
18th Jan 2020 6:05pm |
I was tempted at that price and I already have the earlier version and an IID BT 2016 Skoda Octavia VRS Estate
18th Jan 2020 7:48pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
Snap!. Came out to the same thing 4 days ago. When I start it up it pumps itself up and drives ok but overnight the front passenger side slumps.
18th Jan 2020 8:54pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
I had a suspension warning whilst on the M3 last Saturday, and woke up to exactly the same picture (albeit in Stornoway Grey) the following day, front passenger side slumped!
18th Jan 2020 9:33pm |
Wow.. ok thanks for this it's not just me then.
18th Jan 2020 9:55pm |
Mine were for a 2011 5.0 S/C with Adaptive Dynamics, if you are the 2007 TDV8 listed in your profile then you get to use the cheaper struts without the Adaptive bit . The actual air bags are the same for both though.
18th Jan 2020 11:15pm |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
Same story with mine so both front struts getting replaced Monday all being well.
19th Jan 2020 2:20am |
Yes, although given the springs are basically made of rubber, I'd consider them a wearable component anyway, and would prefer to replace them than many other things on the truck!
19th Jan 2020 10:09am |
Thank you Paul for that comprehensive post, this is very helpful, thanks! 2010 FF 4.4 TDV8 Vogue - Gone
19th Jan 2020 12:31pm |
