Home > Technical (L405) > Sump Removal on 4.4 TDV8
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Has anyone removed the sump on the 4.4 TDV8?
Land Rover are saying it's a 7-hour job, and I'm wondering if anyone has done it and what the procedure is? Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #542562 31st Jan 2020 8:15pm
Baltic Blue
It’s in the workshop manual
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #542567 31st Jan 2020 8:45pm
Zebedee
Many thanks for the reply, Mike.
I'm interested in the sump removal for the L405 rather than the 2010-2012 L322. I suspect it's quite different due to front driveshaft and other bits in the way.
Can anyone point me in the direction of the workshop manual - I'm new to the L405 and just done a search on the forum here with no success. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #542621 1st Feb 2020 11:37am
GraemeS
Australia
You could register with Topix as an independent workshop then pay the small day's subscription to allow you to download the whole workshop manual, section by section.
Post #542622 1st Feb 2020 11:43am
Baltic Blue
If you PM me your email address I will send you the L405 oil pan removal PDF.
Cheers
Post #542625 1st Feb 2020 11:55am
Zebedee
Thanks Mike. PM sent. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #542760 2nd Feb 2020 12:42pm
Baltic Blue
Done Thumbs Up
PS You need to update your profile to reflect new L405.
Post #542763 2nd Feb 2020 1:00pm
Interested to know why you need to remove the sump Zebadee?
Post #542787 2nd Feb 2020 5:59pm
Baltic Blue
So was I Craig, but thought he must know what he’s doing ?
My bet would be oil level indicator not working ..
Post #542791 2nd Feb 2020 6:37pm
GGDR
Yes I think that's what it was on another thread
. Cheers, Greg
Post #542794 2nd Feb 2020 6:46pm
Zebedee
Yup, oil level sensor not working.... Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #542800 2nd Feb 2020 7:51pm
Baltic Blue
I am no expert, but from this picture from the L322 manual , the sensor could possibly be external to the sump ?.
Are you 100% certain it needs to come off ?.
Post #542802 2nd Feb 2020 8:30pm
GraemeS
Australia
External on the L322, internal on the L405 for the identical sensor.
Post #542840 3rd Feb 2020 9:56am
Baltic Blue
That’s interesting Graeme .. I wonder when they changed ?
Early L405’s still needed the turbo drain mod, so presumably same sump as L322, but ? 2014/15 ?
Post #542842 3rd Feb 2020 10:45am
GraemeS
Australia
No, the L405's sump is different to the L322 for more than just the sensor mount which has been inside from the beginning.
Post #542857 3rd Feb 2020 11:45am
