Home > Technical (L405) > Sump Removal on 4.4 TDV8
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Has anyone removed the sump on the 4.4 TDV8?
Land Rover are saying it's a 7-hour job, and I'm wondering if anyone has done it and what the procedure is? Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #542562 31st Jan 2020 8:15pm
Baltic Blue
It’s in the workshop manual
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #542567 31st Jan 2020 8:45pm
Zebedee
Many thanks for the reply, Mike.
I'm interested in the sump removal for the L405 rather than the 2010-2012 L322. I suspect it's quite different due to front driveshaft and other bits in the way.
Can anyone point me in the direction of the workshop manual - I'm new to the L405 and just done a search on the forum here with no success. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #542621 1st Feb 2020 11:37am
GraemeS
You could register with Topix as an independent workshop then pay the small day's subscription to allow you to download the whole workshop manual, section by section.
Post #542622 1st Feb 2020 11:43am
Baltic Blue
If you PM me your email address I will send you the L405 oil pan removal PDF.
Cheers
Post #542625 1st Feb 2020 11:55am
Zebedee
Thanks Mike. PM sent. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #542760 2nd Feb 2020 12:42pm
Baltic Blue
Done Thumbs Up
PS You need to update your profile to reflect new L405.
Post #542763 2nd Feb 2020 1:00pm
Interested to know why you need to remove the sump Zebadee?
Post #542787 2nd Feb 2020 5:59pm
Baltic Blue
So was I Craig, but thought he must know what he’s doing ?
My bet would be oil level indicator not working ..
Post #542791 2nd Feb 2020 6:37pm
GGDR
Yes I think that's what it was on another thread
. Cheers, Greg
Post #542794 2nd Feb 2020 6:46pm
Zebedee
Yup, oil level sensor not working.... Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #542800 2nd Feb 2020 7:51pm
Baltic Blue
I am no expert, but from this picture from the L322 manual , the sensor could possibly be external to the sump ?.
Are you 100% certain it needs to come off ?.
Post #542802 2nd Feb 2020 8:30pm
GraemeS
External on the L322, internal on the L405 for the identical sensor.
Post #542840 3rd Feb 2020 9:56am
Baltic Blue
That’s interesting Graeme .. I wonder when they changed ?
Early L405’s still needed the turbo drain mod, so presumably same sump as L322, but ? 2014/15 ?
Post #542842 3rd Feb 2020 10:45am
GraemeS
No, the L405's sump is different to the L322 for more than just the sensor mount which has been inside from the beginning.
Post #542857 3rd Feb 2020 11:45am
