Home > General > What Did You Do In Your Full Fat Today
Page 299 of 385 <123 ... 298299300 ... 383384385>
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Chlorothalonil wrote:
Replaced the battery with a new one as the car had been standing a while before I bought it and wasn't starting.
I imagine there is probably some threads on here but do you know the specs and process for battery? Im getting a “low battery please start” Every time I get in now. I also understand there are two batteries on these? Which (Location) would I be replacing? Any fancy programming need done or just a simple take out old/put in new and hook up the cables (L322 style...easy). 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #543531 10th Feb 2020 12:22am
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
I used a multimeter on the one under the bonnet and it read less than 12v and the car wouldn't start of course. I simply swapped it for a new one and all was fine. It is a Lucas 020 but I would not recommend it as the battery is much longer than the other and hardly fitted, 390mm versus 370mm approx.
Post #543533 10th Feb 2020 12:37am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Got into mine this morning, first time in a few weeks only to find it wouldn't start. Dash lit up fine, lights working just a click when the button was pressed. Will try to check the battery when I get home (thankfully have a second car) as I suspect it's probably down on voltage having been stood for a while. Hoping it's not starter motor
Post #543548 10th Feb 2020 12:30pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Was informed by a gentleman wearing a Garda ( police ) uniform that apparently the laws of the roads regarding speeding do indeed apply to range rover drivers !!!!! Who knew ??? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #543580 10th Feb 2020 4:37pm
Laughing ... - .- -.
Post #543581 10th Feb 2020 4:41pm
dennij
Got home, took about an hour and a half to fully charge the battery and the car started first time. Guess I need to use it a bit more than I am currently
Post #543608 10th Feb 2020 8:58pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Passed MOT Very Happy . Bit of a cloud on the horizon though Sad , Advisory on rear sub-frame showing signs of corrosion but not yet perforated. I saw the video that was taken and it looks pretty awful. I guess I'll have to get the wire brush out. Any recommendations on coating to use? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #543876 14th Feb 2020 9:18am
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Por 15 2006 4.2 SC
Post #543912 14th Feb 2020 6:39pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Wiper blade on front now noisy . Checked and discovered the blade was disintegrating. Of course the pathetic plastic clip broke when i pushed it in the direction of unlock so as to fit a new blade. Starting to get a bit pee'd off with this vehicle at the moment as the more care you lavish on it , the more it breaks for fun.
Post #543914 14th Feb 2020 6:48pm
appj62
Looks interesting Spud. Thanks, I'll give it an interview. Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #543959 15th Feb 2020 10:14am
DaveK
MOT passed with an odd Monitor and Repair if necessary warning ... shock absorbers light misting of oil rear O/S and N/S. Was driving back when the penny dropped. Changed the two rear stabilser bars last week and had coat everything in that area with gallons of WD40 in an effort to get the Bl@@dy bolts out. !
Post #544475 19th Feb 2020 9:37pm
TrevCOSS
Rear end
Little rear update, reverse lights new plate and gloss black boot strip to match the badges
Post #544828 22nd Feb 2020 8:03pm
EnVogue
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Gave the rangie a gearbox oil flush today. Also replaced the oil in both diffs and transfer box.
Post #545131 25th Feb 2020 5:44pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I played taxi for the children, dropping them off, soon picking one up. In between, I also drove to a Post Office branch office to return a product I bought of Amazon.
Post #545150 25th Feb 2020 7:51pm
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
Went to visit a client and on the way there I collected some documents from the printers, just as well I knew then because I left my wallet at home, then I took Henry (my co pilot the Weimaraner) for a walk before the meeting then home. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #545182 25th Feb 2020 11:53pm
